I need to replace my 17" CRT monitor and 20" (bedroom) TV with either a 17" or (if finances permit) 19" black TFT monitor/TV combination.
Do I simply need to look out for a monitor with a tuner capability?
If this is the only specification I need to look out for will the unit accept a standard (UK) RF input?
If anyone has one and can recommend it I'd be very grateful.
hMany thanks,
Will Hay
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
I know they are out there, but seeing how we are not in the same country I'm not sure what suggestions to make.
I also know that here in the US Viewsonic makes a box you can plug your monitor into and then a VCR or something with a tuner in it and do TV on the monitor or even Picture in Picture with one being DATA the other TV. -
Why not get a TV Tuner card for the PC, and use one or the other of your existing devices?
Cheers, Jim
My DVDLab Guides -
Thanks flaystus.
Originally Posted by reboot
I figure a tv/monitor combination would be a safer bet, and the increased cost for adding a tuner to a monitor would be cheaper than a decent tv card.
In any case, I really want to utilise a liteon dvd recorder upstairs in the bedroom and record via the signal (in the bedroom), so I'll input the signal directly to the recorder and then output to the monitor.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 07:43 -
PC monitor as a TV?
By Lee82 in forum ComputerReplies: 5Last Post: 20th Feb 2009, 09:28 -
HD TV monitor?
By toolady in forum DVB / IPTVReplies: 4Last Post: 30th Oct 2008, 17:28 -
Use DV as second monitor?
By boyerama in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 01:38 -
Monitor
By JonathanK in forum AudioReplies: 2Last Post: 13th May 2007, 16:15
