    Jul 2005
    Florida
    I am trying to find a Recorder that can connect to my PC via firewire so I can transfer files from my PC hard drive to the recorders internal hard drive - does this technology exist?
    If not, what do I have to buy to accomplish this? I need to be able to hook up a recorder directly to my PC so I can transfer video files to it. Rather than using a burner, I choose to use a recorder.
    Thanks,
    Steve
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Why? Unfortunately, I've never heard of a DVD recorder that also doubles as DVD writer. Doubt they exist.
    /Mats
  3. I think there is a Program that works on the "Mac" that will send DV out the firewire into a DVD recorder.
    What recorder?(I dont know).
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    IEEE-1394 PC to DVD recorder may work but with lots of manual handholding and realtime encoder limitations. Better to use an internal burner.
    I'm still waiting for a fully networkable DVD recorder that accepts and burns transfers to the recorder's HDD.
    I'm also waiting for a turn key VHS capture to DVDR solution.
    Don't expect too much from first generation products.
    http://www.kiva.org/about
  5. Originally Posted by Steverup
    No. Only video signal through FireWire which will be encoded to MPG2. No files as it is known in PC world.
