    Apr 2003
    I'm using SageTV to record TV show sin MPEG2. I am then convierting them to XVid or Divx using AutoGK.
    I want to go through and edit out commercials and I have two questions.
    1) Does it make much of a difference (other than the software needed) to do the editing out before to encode them to XVid or if I do it afterwards?
    2) Based on when I do the cutting, are there good FREE programs that I can use to edit the files? Which would you recommend?
    Thanks.
    Mar 2003
    Kansas City MO
    Cut before you convert. I use MPEG Editor (not free) from TMPGENc. Look under the tools section for freeware editors.
    Jan 2002
    You might also try VideoRedo.
