Greetings Fellow Members!
I've recently located into a house with three rooms already wired for satellite TV. I have a DirecTV Receiver connected in two of the three rooms. The satellite cable from outside the house goes to a three-way splitter which feeds the individual rooms.
Due to the way DirecTV designed their channel scheme, a Receiver can't tune a channel located on an odd Transponder while another Receiver tunes to a channel located on an even Transponder at the same time. Unfortunately, I only have one cable that accesses the outside of the house even though the satellite dish has a dual-LNB.
Is there a way I can use that one master cable for each DirecTV Receiver I have in the house without resorting to switchers or drilling holes through walls to have a second cable into the house? I'd like to watch any channel on the Receivers without any worry that it might affect the channel on the other Receiver. Thanks for everyone's help on this issue.
You need to use the LNB dish or get a signal splitter/switch. And not the $.99 splitters like you use on your cable. You need the $100+ splitter designed for SAT tv use.
Google is your Friend -
Greetings!
This would be fine if I had two cables going into the house. However, I only have one cable. Does that mean I need to route another cable into the house to be able to watch from two or more Receivers? -
bingmel:
Investigate this product from Europe:
http://www.dipol.com.pl/esklep/r85148.htm -
Then climb on the roof and add another one. You must have another LNB ($25-50). If you need more than a dual LNB, you have to get a diplexer ($99-200) placed in the attic (fed by a dual LNB!), for either 4 or 8 output.Originally Posted by bingmel
Or better yet, you're paying for the service, get those lazy DTV bastards out to your house and make them install it. It's part of what you pay for at installation (sometimes promos even do it free).Want my help? Ask here! (not via PM!)
Thanks for all your replies! DirecTV is actually visiting this week to install a new satellite dish so we can get more channels. I'll have them do the roof climbing (and drilling, routing, etc.) when they come.
Will the analog lockdown shut off rca out on hdmi receivers when it starts?
By yoda313 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2010, 18:15 -
Are there lan based wifi receivers that don't use usb? (not routers)
By yoda313 in forum ComputerReplies: 11Last Post: 7th Jun 2009, 16:57 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
how to download the transport stream from dvb receivers like SA z65
By phpmysql348 in forum DVB / IPTVReplies: 2Last Post: 4th Oct 2008, 13:20 -
Questions about HDMI receivers
By yoda313 in forum Media Center PC / MediaCentersReplies: 14Last Post: 20th Jul 2008, 19:39
