  1. Hello I have a Flash SWF file and I wanted to make it an mp4 to be played in my motorola e815 mobile phone. Does anyone know how to do this?
  2. Try to convert it by using the "MP4 mpeg-4" preset.
  3. Originally Posted by major
    failed...
  4. Which error? (click the "i" blue button).
  5. Originally Posted by major
    No media found in SWF
    /Users/e1/Documents/pentagon244.swf: Error while opening file
    thing is, it has media, its this flash file.
    its found here.
    www.freedomunderground.org/memoryhole/pentagon244.swf
  6. It seems to work by using "DVD mpeg2enc" with "Decode with Quicktime" enabled. Or you may open it in Quicktime Player, export as MOV MJPEG A and then encode with ffmpegX to anything.
  7. Originally Posted by major
    hey major thanks for the help!
    I tried iffmpegx, but it made the file to huge.
    In quicktime, it did it ok, only the sound is gone...
    anyway to keep the sound?
  8. Try to encode the sound separately with ffmpegX by using the "Movie audio to mp3" preset?
