I accidentally encoded an interlaced MPEG with the wrong field order - is there any way I can change this without having to re-encode from the source file again?
Thanks![]()
Results 1 to 12 of 12
Try using pulldown.exe.
There are many switches and almong them there is one to change field order. -
That's not true.Originally Posted by Abond
Yes, there is a flag for field order and you can change it with ReStream. But... it will make the file look A LOT WORSE. I e-mailed the author of ReStream when I had this problem, he says his tool is just to fix the flag when the encoding program sets it wrong or forgets to set it but actually changing the encoded order doesn't happen.
Because ProShow uses a different field order than my capture card, I have to mix files with different field orders all the time. The ONLY way is to flip the field order on one and re-encode. Sorry.
Here are my quick and dirty notes of what I do:
HOW I SWAPPED THE FIELD ORDER ON PROSHOW FILES
Used Restream to confirm which MPG2 files had which encoding
Found that all of them had top-field-first except for the slideshow from ProShow Gold
Installed the Huffyuv codec
Installed VirtualDub MP2.
Installed the updated Reverse Field Order Filter
Loaded my slideshow into VirtualDUB. Added the video filter and turned off the audio (didn't need it). Set the video compression to Huffyuv. Saved the AVI. This was still a big file: 4.5GB for 6 minutes. I could probably set options to make it smaller, but I wasn't going to keep it for long.
Loaded the AVI into an empty EditStudio project.
Changed the build options to upper field and saved as MPEG DVD.
New MPG2 file loaded great with others and I built the final project with upper field set. -
Then the answer is:
Yes, there is a way, but byteguy has problems with it (me - never). The decission you have to make what to use.
BTW can you elaborate a bit, why it should be worse? I think the encoder encodes FRAMES, but not FIELDS. I am aware that Procoder has field encode mode, but from what I have read, the output is not compliant with existed media. -
I should point out that this is a problem with INTERLACED files only.Originally Posted by Abond
I can't find the cool link to the detail that I read before so here it is from memory...
Say you have a top-field first file.. the frames are encoded
A C E G
B D F H
and are displayed A - B - C - D - E - F - G - H
flip the flag but don't change the encoding and you display B - A - D - C - F - E - H - G and you get a God-awful "jitter" effect
Trust me, I tried to put a top-field first interlaced MP2 from ProShow with a bottom-field first interlaced MP2 from EditStudio and got jitter on the ProShow portion. Then I used ReStream to flip the flag on that input file and the result was some kind of worse double-jitter there. Once I ran it through VirtualDub and used its field flip function and then combined it with the other file everything was perfect.
On a non-interlaced file, it won't matter since the A and B are the same. -
Found the "cool link"
Here is everything you ever wanted to know about interlacing, field order, and general image construction.
http://neuron2.net/LVG/interlacing.html -
All this info I have read already. I know what interlacing means and why the field order is very important with interlaced video. What I never ever seen is this double-jitter you describe there. I have made several encodes with not correct field order, and can see this "normal" jitter in the moving objects, but after correction the field order with ReStream everything was perfect and smooth. So I really can not understand the situation when after correction of the field order with restream it make it even worse - as I said in my case it was OK.
Yes it is.Originally Posted by byteguy
Exactly. Just like the original poster has done, and is asking how to fix.Originally Posted by byteguy
That's not necessarily true either. DVB and DSS formats constantly send MPEG video over satellite that has multiple field orders in the same stream. But I wouldn't suggest this sort of mess to work with.Originally Posted by byteguyWant my help? Ask here! (not via PM!)
So, you are saying that there is NO difference between two MPEG2 files where one is encoded top-field first and the other is encoded bottom field first EXCEPT for the flag?Originally Posted by lordsmurf
The original poster said he had encoded it wrong, not that he had encoded it correctly but the flag was set wrong. You are right, we should have asked "is the field order the way you want it but the flag wrong or are both the flag and field order not the way you wanted?" The answer is different depending on that question.Originally Posted by lordsmurf -
Thanks for your help
I'm not quite sure what you're asking... as far as I was aware, the field order is just a flag which tells the TV in which order to display the fields."is the field order the way you want it but the flag wrong or are both the flag and field order not the way you wanted?"
I encoded the file with TMPGEnc, with the field order set to "Bottom Field First" instead of "Top Field First", like so:
Ok, your file is actually encoded bottom field first and the flag is set correctly. I still stand by my statement that changing the flag with ReStream will not cause it to magically become a top-field first stream.
Have you tried putting this on a DVD? Is it still clear? If so, then don't worry about it. DVD players will interpret the flag on the fly. They will even take multiple movies on the same disc with different settings and deal with them.
It is possible, if all your sources were top-field that you could ReStream this and get a good file. It's worth a shot and will only take a second.
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 14:41 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
VOB2MPG Combines VOB set in incorrect order and skipping the first few min.
By meredithutah in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Oct 2007, 16:03 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 21:32
