Hi,
I had two .VOB files extracted from two different DVDs . Since each of these were more than 2 GB in size , i followed this guide ( https://www.videohelp.com/forum/viewtopic.php?p=1341524 ) for authoring a new DVD .
1) First I demultiplexed the two VOBs using VOB Edit .
2) VOBEdit generated a single .m2v file (Combining both the VOBs) and a .ac3 file
3) Authored a new DVD using Remux option in IFO edit .
Now only I noticed that the second VOB file was of a different aspect ratio , ie 4:3. And this was lost during the demux process at Step 2 . The output DVD movie which IFOEdit produced is of aspect ratio 16:9 , may be becoz the first VOB file had an aspect ratio of 16:9 .
Unfortunately I donot have the ORIGINAL .vob files with me anymore .. I tried reauthoring the new DVD using DVDshrink to extract the second VOB, but that too produces a vob file with aspect ratio 16:9 .
Is there any way to get back my original VOB files with their original aspect ratios ?![]()
rgds
John
Originally Posted by guns1inger
1. You need to split the demuxed mpeg at the point where the change in the AR occurs. This can be done with mpeg2schnitt or cuttermaran.
=> 2 new m2v and ac3 files
2. Patch the wrong header(s) of the second m2v file with dvdpatcher or similar to the correct AR of 4:3.
3. Use authoring software that supports multiVTS for reauthoring. It is possible with ifoedit, but quite cumbersome...GUI for dvdauthor:
https://www.videohelp.com/~gfd/
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 07:34 -
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 18:12 -
Batch Edit of Aspect Ratio for VOB Files
By Lt. Dang in forum Newbie / General discussionsReplies: 3Last Post: 5th Apr 2009, 10:33 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 09:21
