Hi!
I´m new to this forum. I would like to know if anyone knows what kind of program to use if I what to cut a specific file.
The file I have is .dvr-ms
I have tried some programs with no luck.
I´ve recorded shows through Windows Media Center and now I whant to edit them, with no luck. I hope that anyone can help me.
Kind regards
Daniela, from Sweden
StIvan
Check out the following:
http://www.deskshare.com/Resources/articles/dmc_DVRMS.aspx
I do not run Windows Media Centre so the following is only an assumption. There will be some guys on this forum that WILL be able to help you, i'm sure.
It seems to suggest that .dvr-ms are already existing Mpeg2 files; i.e they were recorded to your HD in that format; hence why they may quite large i size. In theory, you should be able to drop them straight into a DVD Authoring program (e.g TDA) and output as DVD Compliant files and then burn; Highly likely you will have to shrink before burning (DVDShrink). TDA will allow you to edit/cut your file as you requested. I would suggest you give it a try anyway because this will help you learn some valuable steps in dvd authoring and the use of compressing files via shrink prior to burning. -
try videoredo or tsunami mpeg dvd author pro, authoring toool but with built in editing and dvr-ms support.
and please use a better subject next time...I added cut dvr-ms.
What program can I use to cut segments from a mp4 video?
By alc112 in forum EditingReplies: 9Last Post: 1st Jul 2011, 18:31 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 00:52 -
A simple but affective program that i can simply place different avis and cut?
By Mozzy31 in forum EditingReplies: 5Last Post: 10th Feb 2010, 06:56 -
Hauppauge HD-DVR - Final Cut Pro
By cnolan011 in forum Capturing and VCRReplies: 4Last Post: 8th Nov 2008, 06:56 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 15:55
