I used the bitrate calculator and came up with a bitrate of 5400
this is a photo slideshow with music, approx 145 mins
photos from a digital camera
what are the chances of this coming out fairly decent at 5400
im using tmpgenc CBR
its encoding now
DVD PAL (MPEG-2 720x576 25fps CBR 5400kbps)
im not really too familiar with bitrates on slideshows, but i know thats what some (lower end) commercial dvd's use, and they probably use lower quality sources than that, too................it should end up looking pretty good, i'd guess...........let us know how it turns out.......my only gripe with the settings that you used (mind you, im a stickler for pure quality) i wouldve personally gone with 2 pass VBR...it would take a pretty long time to do if its 145 min though.....
Hi sifaga,
You may well even find that 5,400 is too high. I know it sounds weird, but I've encoded slideshows (originals were high quality JPEGs dropped into Premiere and frameserving to TMPGEnc Plus v2.5) and got macroblocks when encoding CBR at bitrates around that mark.
Try:
1) CBR at lower rates - i.e. experiment.
2) 2-pass VBR with 5,400 as the average, max 8,000 and min 500. I've had personal success with these settings and the process I described above.
Either way, there is a setting in TMPGEnc (under the Quantize tab I think) called "No half motion by pixel" - or words to that effect. Try ticking this.
Good luck..There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You could also try CQ (versus CBR or VBR) and let TMPGEnc Plus set the bit rate. CQ is slightly slower than CBR but much faster than 2-pass VBR. For a slideshow I suspect CQ mode will give you good quality. Might be worth a try.
thankyou for the info all
Im trying out a few of the suggestions
video slide shows make huge files out of stills because you're making tons of frames to show each still. if this is for the web, you 'd probably be better off using a javascript or php slideshow script.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
ECS GF8200a Mobo will not overclock w/ BE AMD 64 X2 5400...
By stedyone in forum ComputerReplies: 17Last Post: 27th Mar 2009, 03:40
