I have created a little project to start learning about video, namely to create a VCD from an AVI. I think I did a pretty good job by first extracting the AVI audio stream (AC3) to a WAV. Then I used MainConcept Encoder to create a VCD, using the original AVI as video source (encoded with XVID) and the separate WAV file as audio source.
What exactly happened during the encoding process? I think the audio is relatively clear, a WAV file was compressed to an MPEG, but how did the XVID video stream on the source AVI get decompressed and then recompressed as MPEG?
I realize that the resolution of VCD is quite poor (350 x 240) but I'm wondering how you control the size of the image on a analog TV set? Does the TV just draw a 350 x 240 sized picture on the TV screen. How much will the video fill the TV screen of a standard analog set?
Thanks in advance for your patience and understanding.
This might help:
http://forum.doom9.org/showthread.php?&threadid=63587
Although it's part of a transcoding FAQ, it gives a concise description of MPEG encoding. It probably wouldn't hurt to have a peek at the glossary <-- over there, for instance look up "compression", "codec", etc.
Good luck.Pull! Bang! Darn! -
Originally Posted by satwar
Originally Posted by satwarRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I don't understand these errors saying "wrong version".
By saltyjd1 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Mar 2011, 14:52 -
I Don't Understand video language
By capnralls in forum SubtitleReplies: 4Last Post: 29th May 2010, 10:09 -
I don't understand why I can't edit my .mp4 videos?
By JohnBarnshaw in forum Newbie / General discussionsReplies: 10Last Post: 13th Jan 2010, 18:43 -
/shrug - Now What Don't I Understand
By macbuz in forum MacReplies: 2Last Post: 12th Jan 2009, 17:21 -
Still don't understand .avi to DVD input/output
By sknox in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jul 2007, 13:51
