My XBR413 is about 3 months out of warranty and will no longer record (or play) DVDs. It will play CDs and CDRWs just fine. Zenith wants over $250 to replace the DVD-RW drive, so I'm going to try to replace it myself. I have pulled the drive out and installed it in my PC with similar results. I replaced the drive with a DVD+-R/RW drive, but it does not work (yes, I tried a new IDE cable and checked the jumpers first). Does anyone know what the OEM is for the DVD-RW drive that is in the Zenith XBR413? I called Zenith and they can't (or won't) tell me.
Thanks in advance!
- Jack
It's definitely a proprietary LG Drive inside. I opened a unit up before and I thought it listed the model number of the drive right on top of it. Also if you install it in your computer the device manager should list the model number.
Alas, this won't help. It's made specifically for the unit and another drive (even an LG) won't work. It'll just say "Please Wait" and eventually turn off.
How do I recover the OEM portion of Hard Drive?
By TreeTops in forum ComputerReplies: 19Last Post: 21st Nov 2011, 01:53 -
Zenith (LG) XBR413 Firmware Update?
By shatner in forum DVD & Blu-ray RecordersReplies: 6Last Post: 2nd Dec 2010, 02:07 -
Reauther dark OEM DVD. Help! Please!
By p71rock in forum Authoring (DVD)Replies: 10Last Post: 26th Jun 2009, 00:46 -
Tuner for Zenith XBR715 VHS/DVD(burner)
By solarblast in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2009, 12:03 -
I have a question about my Zenith DVB412 DVD Player.
By Mr. H. in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Dec 2008, 17:16
