Results 1 to 15 of 15
    Jul 2002
    Porto - Portugal
    Hi, I use Premiere Pro 1.5 to capture and edit my videos, but have some doubts when converting the AVI file to DVD.
    Usually I use the Premiere option "Export to DVD" and it does all the convertions and burns the DVD, but I think that the final quality isn't great.
    I thought to use the "Premiere Pro Video Server Plugin" and frameserve to "TMPGEnc 2.5 Plus".
    Shall I got better DVD image?
    Any help?
    Thanks in advance,
    Miguel
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Give more info on your
    1. Source File
    2. Project settings
    3. MPeg2 encoder settings
    You should be getting very good quality if the source is also very good.
    http://www.kiva.org/about
  3. I agree with ed.
    Ppro uses mainconcept mpeg2 encoder. If you are thinking you will see a huge difference from mainconcept to tmpgenc to procoder to a whole slew of other mpeg2 encoders...probably not. You can read and do comparisons untill your blue in the face between encoders, but you should be just fine with the built-in mainconcept encoder.
  4. Member daamon's Avatar
    Melbourne, Oz
    Originally Posted by mc4
    I thought to use the "Premiere Pro Video Server Plugin" and frameserve...
    I don't know if you have to pay for that plug-in, but the Debugmode Frameserver is great, it works with Premiere Pro 1.5 and is free. I use it alot.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Jul 2002
    Porto - Portugal
    Originally Posted by edDV
    1. Source File
    2. Project settings
    Hi edDV,
    Footage of DV video, captured with an "Helmet Cam" that injects the video+audio in a Sony DV cam.
    Premiere Pro:
    Video Settings
    Compressor: None
    Frame size: 720h 576v (1.067)
    Frame rate: 25,00 frames/second
    Pixel Aspect Ratio: D1/DV PAL (1.067)
    Color depth: Millions+ of colors
    Quality: 100 (out of 100)
    Fields: Lower Field First
    Audio Settings
    Compressor: Uncompressed
    Sample rate: 48000 samples/second
    Channels: Stereo
    Sample type: 16-bit
    Export from Premiere Pro 1.5 with Premiere Pro Video Server to TMPGEnc Plus
    Settings of TMPGEnc:
    Stream type: System(video+audio)
    4:3 display
    25 fps
    CQ 2000/8000 Kbps
    Interlace
    10 bits
    Highest quality
    GOP 1-4-1-1-15
    I hope this help. Thanks
    Miguel
    Jul 2002
    Porto - Portugal
    Hi daamon,
    Thanks for the input. I'll try also Debugmode (as you sayd it's free) and compare it.
    Thanks,
    Miguel
  7. Mc4,
    what were your mpeg2 encoder settings when you exported from premier using the built in mainconcept encoder? I would be surprised if your output from tmpeg is of noticable greater quality than that of ppro's built-in mainconcept. (given comparable settings of course)
  8. Member edDV's Avatar
    Mar 2004
    The internal Mainconcept MPeg2 encoder should have worked fine. Are you saying the MPeg2 encode resulted in lower quality compared to the DV timeline? Maybe the encoder settings were wrong.
    TMPGEnc Plus is slower but should also give good results.
    Jul 2002
    Porto - Portugal
    mike909,
    Thanks for your input. If you're right about the built-in Mainconcept Encoder, maybe it's a loss of time trying to get better encode quality.
    As you saw in my other answer, I get the video from an Helmet Cam, so the image isn't as good as we want and I thought that I can have a better encoder to compensate ...
    Regards,
    Miguel
  10. Mc4,
    If you have the time, it can't hurt to experiment on your own with other encoders. Generally speaking though, it probably won't help in your situation. As Ed has asked, the "final quality" you are speaking of...is that compared to the DV Timeline in premier? It sounds like your source footage may not be as high quality as you are looking for, in which case...no encoder can help. You may want to experiment with some Ppro video filters/plugins. (ie. magic bullet editors has a nice way of adding/changing color). Simply changing tint/hue/saturation etc. can surprisingly produce nice looking DV sometimes. Good Luck.
  11. Member edDV's Avatar
    Mar 2004
    Post some sample frames and we may be able suggest filters.
    Jul 2002
    Porto - Portugal
    Guys,
    Sorry for the delay. I was trying some different settings, but as I have some images that change quickly ( shooting from an helmet cam in a offroad motorcycle) I don't like the final quality f the DVD, so maybe I didn't use the right settings in the encoder (built in Mainconcept Mpeg Pro).
    Here are the settings I use:
    General:
    Disc Name: Moto_TT-3
    Timeline Markers: Yes
    Loop Playback: No
    Preset:
    Custom Preset
    Comment: High quality, CBR transcoding of DV content
    Video Summary:
    Codec: MainConcept MPEG Video
    Quality: 5.0 (high quality)
    TV Standard: PAL
    Frame Rate [fps]: 25
    Field Order: Lower
    Aspect Ratio: 4:3
    Frame Width [pixels]: 720
    Frame Height [pixels]: 576
    Bitrate Encoding: CBR
    Bitrate [Mbps]: 7.9720 (high quality)
    M Frames: 3
    N Frames: 12
    Audio Summary:
    Audio Format: MPEG
    Codec: MainConcept MPEG Audio
    Audio Layer: MPEG-1, Layer II Audio
    Sample Size: 16 bit
    Frequency: 48 kHz
    Bitrate [kbps]: 384
    Encoding:
    Export Range: Entire Sequence
    Fields: Lower
    Maximize Bitrate: No
    Force Variable Bitrate: No
    DVD Burner:
    Burner: E:\PIONEER DVD-RW DVR-109
    Speed: Auto
    Burner Status: Ready
    Number of Copies: 1
    Record Options: Record
    If you have any sugestion, I'll apreciate :P
    Best regards from Portugal
    MC4
  13. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    It looks like the only thing that can help you is a better camcorder. You should have got great results with the settings you choosed.
    If you're getting lots of macroblocks, you may want to experiment with some filters like convolution in Premiere Pro or Virtualdub.
    I didn't know they raced dirtbikes in Portugal, I was actually born near Chaves......not to far from Porto. I now live in the US where there's lots of dirtbike racing among others.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
    Jul 2002
    Porto - Portugal
    Originally Posted by dipstick
    If you're getting lots of macroblocks...
    Hi dipstick, the problem is not with macroblocks but we could say "microblocks", It's like a pixelisation of the movie, the image is granulated and not very crisp and smoth, I don't know if I can explain it.
    As this happens more when the images change more rapidly, maybe I must use other GOP settings to get the best quality. What do you say?
    I didn't know they raced dirtbikes in Portugal ...
    Now, about dirt bikes in Portugal, for many years, maybe since the 80's, we have lots of them here in Portugal. Near Oporto where I live, we have many places to ride (till now it's allowed) and every weekend I with my CRF 450X and with some friends go ride and make some movies.
    Nice to ear from you and regards
  15. Your settings look fine, and that 'should' give good results. If you could post an image of your source and the same image of the resulting mpeg2 that would be very helpfull. It sounds to me like your source footage just isn't as clear as you want it to be. Kind of like when I shoot indoors with my canon zr-50mc without good lighting (it's very grainy and low quality looking).
