ok...what I have here is 4 .vob files that I need to make into a dvd. My .bup files or something else must be corrupt and I just want to know what to use to make these into a playable dvd. My source is gone or I would just start over from scratch. I can open all 4 of these .vob files in PowerDvd or WMP so I know the .vob's must be good. Thank you for any answers and just FYI....I DID search on how to do this and just got lost.
If at first you don't succeed; call it version 1.0
I assume that these 4 VOBs are one continuous movie or something ?
If so, rename them to VTS_01_1.VOB through to VTS_01_4.VOB and then follow the instructions here:
http://members.dodo.net.au/~jimmalenko/test.htm#ifoeditIf in doubt, Google it. -
ok Jimmalenko, I will try that and post back my results in a day or two. All of a sudden I got real busy here. Thank you for the advice.
If at first you don't succeed; call it version 1.0 -
Thank you very much Jimmalenko, that worked like a charm and didnt take too long either. I appreciate the help!
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44 -
Cutting .vob file in .vob format only
By rahul.never2far in forum EditingReplies: 11Last Post: 1st Oct 2007, 09:52
