Results 1 to 13 of 13
  1. I am trying to back up a commercial DVD. It gets about 1 minute into it and comes up with a series of error messages.
    "Read failed for 512 blocks at 8192"
    "Mirror of Title set 1 failed"
    "Mirrir is DVD failed"
    I also tried with DVD backup and there was an error message on that program too. I actually watched the DVD on my computer first, so I know all the 'keys' are there. Also MacTheRipper detected Disc RCE, I dunno if that has anything to do with it. I have the RCE Region set to RCE 1. I also have De-Macro on. I am a newbie so I don't know what all of these things mean, but I know it has worked in the past.
    Any suggestions?
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    version of Mac The Ripper?
    Sounds like there might be dirt on the DVD.
    Did you try cleaning it first?
    I've found that in the past this has done wonders
    to get past block read errors......
    following that, you may want to go
    over to the Mac The Ripper Forum
    and download the newest version
    ( via donation).
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. I downloaded the new version. On the program it is saying there are bad sectors. But its getting past them and now its back to normal. Hopefully my DVD will play ok. Not sure though if it found bad sectors...
    EDIT: Also...with MacTheRipper do you have to watch each scene for a few seconds like it says in the Walk-Thru or is that just with DVD Backup?
    Aug 2005
    brighton-england
    i'm using v 2.6.6 and i never had to watch any part of the disc before ripping.
    i've had a couple problems burning discs after ripping with MTR, but got round that in the end. if your a newbie (like me) check my post on burning, it's called "video ts folders to large to burn". might be of use
  5. Member terryj's Avatar
    You would then process the MTR rip with a re-quantumizer like
    DVD2ONEX ( or, possibly Popcorn) to a new
    VIDEO-TS folder , that you would burn in Toast.
    Should be fine....
  6. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Make sure you've set your DVD drive's region by playing a commercial DVD with DVD Player.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  7. I know how to compress it and all that. I've just never seen that bad sector thing before.
    How would I check the region on the DVD player?
  8. Member terryj's Avatar
    when you put in the first commercial DVD of your choice,
    and then play it using Apple's DVD player,
    if you have never played a DVD before it will
    prompt you to set the region of your drive.
    so say for instance if you've watched Spider-Man
    that you picked up at Wal-mart/Best Buy, then
    it would be set for Region 1.
    Urban Mac User
    Jan 2005
    Internet
    If you did this why are you not asking for help in the MTR forum?
    You have to be a member of the MTR forum to get the newest download unless you found it somewhere else?
    Mark V
    10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D
  10. I found it on a different site I guess. Someone on this board posted a link. I didnt even know there was a MTR forum.
    Jan 2005
    Internet
    http://www.ripdifferent.com/phpbb2/index.php
    Here is the link. you can get the new updated version here.
    Mark V
  12. Shawn probaby downloaded 2.6. 3.0 in the current (donation) version (still considered beta, I believe).
    Jan 2005
    Internet
    Yes but 3.0 has been working flawless on the newer movies.
    Mark V
