I want to know if it's possible to demux a single VOB file---substitute a different AC3 file---then remux the VOB file, then return it to the original VOB set in the VIDEO_TS folder.
Can this be done without demuxing and remuxing the entire set?
If so, what tool or tools do I need to do it?
Jake
If the different AC3 files are CBR and the new AC3 has exactly the same properties as the original AC3 file (same size in bytes, same duration, same number of channels...) it should be possible. But I don't know any program that would support such a thing...
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Are you sure that the VOB file contains only the video you want to change, and nothing else ?
This isn't exactly the same, but it's damn close.
https://www.videohelp.com/forum/viewtopic.php?t=234240Read my blog here.
question on vob files
By rtr720 in forum Authoring (DVD)Replies: 12Last Post: 17th Jan 2010, 12:00 -
VOB to avi question
By nalooti in forum Video ConversionReplies: 2Last Post: 3rd Jul 2009, 18:16 -
VOB question
By danielmak in forum MacReplies: 4Last Post: 5th Sep 2008, 21:02 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2008, 00:16 -
VOB Question (last one i promise)
By jordanwalkert in forum EditingReplies: 1Last Post: 8th May 2007, 03:37
