Does it only make DVDs, or can it also make VCDs & SVCDs?
Does it offer the option of a simple interface for newbies or is it a professional tool for experts only?
Results 1 to 9 of 9
Yes, it will make all mentioned. Read the info on the upper left labeled "what is" to get the right specs i.e. resolution, bitrate setting, audio's ect. It Just encodes, it wont author for you though.
Quality is my policy. -
Originally Posted by Stormin Norman
I haven't used Procoder in over a year but isn't this your start screen?
http://www.canopus.us/us/products/procoder2/i_wizard_b.jpgRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I never use the Procoder wizard. I'm not stupid, I know what I'm doing, don't need my hand held. Plus the wizard has a way of hiding the advanced options.
Just something to consider.Want my help? Ask here! (not via PM!)
Just click on the vcd or svcd in your target then satwar. The Template should take care of the rest.
CinemaCraft and ProCoder are both pretty good chunks of software, personally though, id go with procoder just on basis of ease of use, i think procoder actually produces slightly better picture quality, too.....
Are there some advance settings accessable in the Express Version?
Newbie bluetooth questions
By videohalp in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2011, 04:37 -
newbie questions about ffmpegx
By Anoni in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 10:11 -
Considering a Canopus ADVC300 - further questions
By Pixelrage in forum Capturing and VCRReplies: 13Last Post: 1st Dec 2010, 12:36 -
Canopus ADVC 110/300 - These Questions have been asked before but I can't..
By Anonymous4 in forum Capturing and VCRReplies: 9Last Post: 21st Nov 2008, 18:14 -
VHS to DVD with Canopus ADVC110 - mostly filter/cleaning questions
By Z-C in forum RestorationReplies: 121Last Post: 14th Jun 2007, 05:55
