Hello,
It seems as though people have very strong opinions either for or against, when it comes to the use of Monster cables. Some say they are all hype and are actually bad quality.
Does anyone have any experience with the "Cable Pro" brand of S-video cables?
How do they compare with the Monster brand, specifically regarding S-video and audio cables?
Here is the link for "Cable Pro":
http://www.thecablepro.com/
Thanks,
Results 1 to 11 of 11
Monster cables come in different grades. They are usually OK quality but are sold with major advertising hype and high retail markups. Retail incentives (commissions and contests) cause your local retail salesperson to push these cables at prices 2-4x over equivalent cables purchased on the internet from other sources.
One internet retailer I trust so far is http://www.ramelectronics.net/Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Cables have min standard when they are manufactured, but some are more beautiful and more expensive. For short lengths they are all the same just buy the one that impresses you. Monster cable are very expensive eg if you need one that is long to reach your projector or HD TV the price difference could be a lot!!
Having used a variety of different cables, I can tell you that Cable Pro has some of the very best video cables available at any price. They are way better than even Monster's top-of-the-line M1000 cables. I haven't tried any of Cable Pro's audio cables, but I would guess the same. I am using Signal Cable Silver Resolution audio cables for the moment and am satisfied with them (though they are quite expensive at $160 per 3-foot pair). Come to think of it, Signal Cable's s-video cable at $29 even beats Monster's $60 M1000 cable. http://www.signalcable.com/
Originally Posted by piano632
$61 for a one foot cable and $4/ft for more? For S-Video?
Why would anyone pay these prices?
NTSC is very limited on bandwidth regardless of cable performace. This is like putting NASCAR $2000 tires on an Chevy Nova.
http://www.thecablepro.com/cableDetail.php?cID=74&cgID=1Recommends: Kiva.org - Loans that change lives.
http://marketware-tech.com/ausca.html -
I've been through the cable phase with the thought that the more one pays, the better the sound. Wrong!!! I can sit in front of the Tektronix scope and cannot see, nor hear any difference.
Reference system is:
Levinson 33H mono Amps
Genesis 200 series towers
Musical fidelity DAC
Levinson Pre
2 channell
4 Bryston 7BST mono Amps
Bryston BP 25 Pre
Musical Fidelity DAC
Infinity RS1b speakers
2 channel
Both run as HTPC to the Electrohome 8500 CRT projector. Sound stream carried by a Fiberfin toslink cable. Cost for the cable: $18.00 All sound is 2 channel.
Both setups sound superb as it is Redbook standard on CD playback.
Mark -
I come from a car audio background and been through the cable wars over on that side.
All I can say is this -
Sometimes cables make a difference but maybe its how your system is setup. Sometimes you get a bad quality cable included with whatever electronics you get. You just assume because its new that it should work right. Not always the case, if you have a funky picture with say your S-video, try a different S-video cable before you go out and buy $20 Monster Cable S-video cables or anybody else's for that matter.
I mean my A/D/S DIN cables sound just as good as $20 per foot Tiffany cable....Project Digital: Eliminate All Physical Media is finally underway!
Is using S-Video cable better than using RCA cables to capture video?
By snafubaby in forum Capturing and VCRReplies: 21Last Post: 7th May 2020, 08:16 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 20:03 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 08:38 -
RCA cables or S-video?
By effects in forum RestorationReplies: 3Last Post: 10th Jul 2007, 06:03
