I have been working on a little DVD for my brother's baseball team which is just a bunch of pictures like a slide show, I added music but while it is playing it stutters every now and then, is there something I can do to fix this? The music files are on my hard drive and play fine when you listen to them through Media Player or something. I am using Intervideo Win DVD Creator.
Does it stutter at the exact same point every time you play the disc or does it change?
It happens at different times every time I play it. Also I didnt burn it to a DVD yet because I figured it wouldnt make a difference, I have been watching it in preview.
That would indicate the problem lies with the computer and not your show. Try burning to a DVD and put it in a stand-alone player and see what happens.
And don't do anything else on your computer while you burn. . . . It's probably your HD that creates the problems
You may need to defragment your hard disc. If it is fragmented, it can cause this type of problem. When you work with audio and video, it is important to defragment your hard disc regularly.
Well, I took you suggestions and that seems to have made the difference. Thank you, all of you
Sound is stuttering
By GeordieDave in forum Newbie / General discussionsReplies: 7Last Post: 19th Apr 2011, 17:21 -
Playback of DVD authored with multiple angles has stuttering sound
By kipling100 in forum Authoring (DVD)Replies: 2Last Post: 14th Nov 2009, 21:54 -
Stuttering on PS3
By wjfisk in forum DVD RippingReplies: 10Last Post: 7th Apr 2009, 13:15 -
DVD stuttering
By Koron in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2008, 14:16 -
DVD stuttering
By bakerbj in forum Newbie / General discussionsReplies: 3Last Post: 31st Oct 2007, 10:37
