I have tried to capture Divx using VirtualDub following the guide on these pages but it seems that the files is gonna take up a lot filesize (about three cd's or so for a movie) - so my question is, what are the correct settings in order to keep a 90-110 min. movie = 700mb or below?
Thanks - apreciated!
Try no higher than 1100 if size is 352x240.
"Oh I see! You'll use brute force when you can't get something by arguing for it..." -
Did you follow the step of converting the audio after you did the capture?
If you are capturing CD quality audio and don't compress it using MP3 or some other audio compression it will take 1.5 CDs just to hold the audio. -
Yes, I guess I've solved the problem now and I just encoded a movie with an almost exellent result. I used the new codec4 beta and remembered to encode the sound into mp3.
Thanks a lot for your help!
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Lagarith codec producing larger filesize with smaller resolution?
By BozQ in forum Newbie / General discussionsReplies: 22Last Post: 15th Sep 2009, 11:11 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22 -
Capturing from VHS to divX: Recommendations (Flicker & freezing proble
By roylayer in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2008, 18:00
