Anybody else experience this?
I have two DVD Burners that have each decided they no longer like either + or - media.
The first, and NEC 1300 decided it will not burn - (minus) media now.
The other an IO Magic (Optorite) DD0401 no longer will verify + (plus) Media.
(It will burn, but will not verify, disks show no read errors with dvdinfo)
All software is current, Nero, and DVD Decryptor both experience this problem.
Tried with different media in both cases, different speeds, etc.
Is it possible for only one 'side' to fail?
Are there two different lasers, one for each media type?
Just curious.
There is a read laser and a write laser, and AFAIK, 2 more for CD read, write.
You likely have more than one problem there. Have you tried cleaning the laser lens? You can start with 'canned air' to see if it helps; If so, a cleaning disc or better a foam Q-tip and some denatured alcohol. Keep the Q-tip damp, not wet and change often.
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
movies on Hard drive fail to to burn
By dymx in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Apr 2009, 05:53 -
Writing fail with Img Burn
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 05:02 -
Why did I fail to use WinAVi to burn a DVD movie?
By efang622 in forum Authoring (DVD)Replies: 8Last Post: 29th Oct 2007, 13:12 -
After a new burner and media.
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2007, 11:03
