Hi All
I think there is something wrong with my DVD rom but before i buy a new one i just wanted to ask your advice.
It seems to read discs ok however i went to put a Audio CD in it doers not read it correctly. the sound fades in and out and it sounds like the drive has trouble reading it.
can anyone give me any help with this or is it better to just replace it.
oh, i have it as my master with my DVD writer as the slave.
May need cleaning. The CD laser and the DVD laser are separate. If one works well, the other may not. You can try a cleaning disk or my preferred method is a foam Q-tip and denatured alcohol. Not too wet on the Q-tip. You can also try some 'canned air' first to see if that helps. If so, then it definitely needs cleaning. If the drive won't work, you have little to lose, even if you have to partially disassemble it to clean it.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 11:49 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 02:49 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
