Hi All
i have started using Proshow Gold and from what i have have seen htis is a great program.
Im going to keep fiddling with it to see what it can do but i have one question for anyone who has used it. Can you have a main menu and then sub menus?
i am currently puting together a slideshow for my brother in law who just got married. what i want to do is put both the engagement picture and the wedding pictures on the same DVD.
we would start with a main menu with two options egangement and wedding. if you choose engagement then you go to a sub menu with 3 slideshows. and the same for if you select wedding.
can this be done?
Hi Peter H,
I don't use Proshow Gold, so I don't know if it does menus.
However, if it doesn't, an easy option would be to use that software to create two slideshows: one for the engagement and a seperate one for the wedding.
Then, during the authoring of the DVD, put each slideshow into a seperate track. You can then create a menu with two options, each option going to it's respective track. Problem solved...
This is by no means an unusual way of doing this, and is easy to do. TMPGEnc DVD Author is good software to start with if you're new to DVD authoring, and will easily do what I've suggested.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by daamon
i use DVD Lab Pro, could i use this to generate the menu system for the dvd? -
Originally Posted by Peter H
There's some great tutorials over at the DVDLab Pro website.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Need some help with Photodex ProShow...
By cmcfalls in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2009, 13:08 -
Photodex ProShow Gold or Memories on TV for DVD Slideshow
By jet757f in forum Newbie / General discussionsReplies: 13Last Post: 8th Nov 2007, 12:44 -
Proshow Gold Chapters
By marioval in forum Authoring (DVD)Replies: 1Last Post: 30th Oct 2007, 12:38 -
Does ProShow Gold hate -R blanks ?
By Seeker47 in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2007, 20:11 -
ProShow Gold will not burn my show to DVD
By Kleea27 in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2007, 23:53
