  1. Whenever I try to make a copy of a copy I get the dreaded I/O device error.I've tried Dvd shrink,clone dvd,nero express and others,nothing seems to work.My burner a matsushita sw 7595 seems to work well when backing up original material.It is only copied material it has problems with.Anybody out there care to help me out?
  2. Member R55B's Avatar
    Aug 2005
    Florida, USA
    Try this:
    http://support.microsoft.com/?kbid=149962
    You may have a conflict within the driver setup with your burner. DRM can really interfere with copyrighted material...
    Feb 2004
    Australia
    1: can you play it on pc ?
    2: If possible , and you have a freind with a dvd drive , try copying it with their unit .
    3: A bios update for unit may be available , check with manufacturer ..
    If it dosent work then the io error , which is meant to be a system error , is actually only partially correct , what it should be saying is disk read error , meaning inferior material or duplication process error , or an actual system problem , however the last dosent seem possible if original material has no problem .
    Try using the nero cd/dvd tool and see what it has to say about the media ...
    There is some information regarding older dvd writers not being compatable with discs created by newer dvd burning models .
    The other issue could be due to a faint scratch near the bootsector (center ring) which will cause this problem , and may be repaired using a cd/dvd scratch removal sollution .
    There was also a copy program that had this issue , but I cant be sure if it was dvdxcopy that done this initially , or another product , but it prevented the creation of copies of copies , I'll have to go back and investigate those tools again ...
    If you do have another dvd drive available on another pc , it would be of an interest to install pgcedit , and get it too load the dvd , and see who the author is , then it may give an indication as to the culprit which caused the initial problem .
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Try DVD Decryptor.
    You could also just copy all of the files from the DVD onto your HD and then burn.
    Google is your Friend
