Is there any way to make Final Cut Pro 4 understand a bunch of different file types? Mov, RM, etc?
Thanks.
Your choices for ingestion into Final Cut pro are:
.DV ( digital Video)
anything outside of that must be rendered into
.DV format.
You would think .mov WOULD, but it can often produce
out of sync audio. Best to convert to .DV stream.
As for .RM ( Real Media) , Soreson Squeeze maybe....? -
I could swear Ive taken in .Mov files and I thought AVI or some form of Mpeg. Are there any type of codecs to make the files read?
Thanks Again for you help.
Much appreciated. -
no.
Even with all the QT Codecs installed
( 3iVx, divx 5.21, the QT MPEG-2 plugin)
the footage would still have to render to .DV stream
on import.
.Mov, provided both video and audio are in codecs QT likes,
possily could, but every one I've ever tried produced out
of sync audio, that could only be fixed by exporting the .mov
out of Quicktime Pro to .dv stream, then re-importing
into FCP."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Joboshare dvd copy produced a bunch of files I dont understand
By rocks911 in forum DVD RippingReplies: 1Last Post: 31st Aug 2011, 22:38 -
I dont understand .mkv files at all!
By InfernoParadox in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 01:21 -
cant understand how to mux all files into MP4 with XVID4PSP
By d2idan in forum Video ConversionReplies: 1Last Post: 4th Jul 2008, 22:58 -
need to understand 16:9 DV format
By jmwismer in forum Newbie / General discussionsReplies: 5Last Post: 28th Dec 2007, 19:47 -
trying to understand kbps??
By icucmerc in forum Video ConversionReplies: 6Last Post: 5th Aug 2007, 00:58
