Here is a description of my current project:
My main hobby is djing, and I decided to make a 5.1 surround sound mix. I've got that part done...then I thought, why not add some video to it and make it a full fledged DVD. Well I decided to rip scenes for 2001:A Space Odyssey and edit them to go with the mix. I used ffmpegx to rip the DVD VOBs to Mpeg-4 H.264 at a hight bitrate. These turned out very well. I couldnt distinguish these from the original DVD. There were no visible artifacts at all.
I painstakingly ( I have an old dual 450 mghz G4) arranged these clips in Final Cut Express, then exported the final movie last night to just a vanilla Mpeg-4 .mov with the best quality on. After roughly 20 hrs of exporting for a 38 minute movie it was finished. But with noticable artifacts.
Here is my delima:
1) I want to export this movie and then burn it to DVD. So I want to have the highest quality source file before it goes through another round of encoding (mpeg-2) for the DVD.
2) I want it to remain in anamorphic widescreen. I edited the files at 720x480 and you could tell they were squished. So I figured once i send them to DVD studio Pro, I can mark them as anamorhic and they will play properly on my widescreen TV.
3) After importing the 24fps files into Final Cut Express and then exporting and reencoding into Mpeg-2...will a DVD player be able to recognize the source footage as 24 fps progressive with 3:2 pulldown?
but my highest priorty is number one....so should I:
A) export the FInal Cut Express Video as 1) an FCP movie, or 2) as a quicktime file?
B)if quicktime file, should I select DV, or mpeg-4 h.264? What will give me the highest quality before I send this file to the compressor for mpeg-2?
thanks in advance for any advice.
"Good Luck 007"
In Memory of Desmond Llewelyn
Transcoding Software
By Prince Valiant in forum Video ConversionReplies: 4Last Post: 11th Sep 2010, 10:26 -
Free video encoding / transcoding service?
By jmd01 in forum Newbie / General discussionsReplies: 8Last Post: 15th Jul 2010, 14:12 -
Different Transcoding on Encore
By htalnts in forum Authoring (DVD)Replies: 1Last Post: 14th May 2008, 22:42 -
XP vs Vista (transcoding)
By stiltman in forum ComputerReplies: 17Last Post: 11th Sep 2007, 11:36 -
Batch Transcoding?
By joelore in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2007, 16:42
