Okay i have PearlHarbour and i used to dvdremake to remove features now i want to run it thru dvd rebuilder and cce the first time through it left me with a 2gig movie output which is not what i expected
thread to question bout dvdremake
https://www.videohelp.com/forum/viewtopic.php?t=279832&highlight=
anyways now i was wondering what to do with multiple angles/interleaving source movies and CCE using dvdrebuilder pro
Results 1 to 11 of 11
please somebody must know the answer iv looked everywher
Hi-
Well, do you want to remove the angles, or keep them? You didn't say. If you want to keep the Angle/ILVU, then run it through DVD-RB Pro as is. I haven't had any problems with the 2 I've done. Using DVD-RB v1.00 RC5.1 If you want to remove all but 1 Angle, then either do it in DVDRemake or IFOEdit before sending it to DVD-RB. I've had success with DVDRemake removeing angles, but not ILVU, the Disney kind where you get the credit languages flipping back and forth. Maybe it was just me, I don't know. Anyway, IFOEdit did it OK. Here's a guide:
http://www.doom9.org/mpg/ifoedit-branchingnotes.htm -
@CrisCrOss, I use Dvd Rebuilder Pro/CCE Basic and use it as my primary tool, especially when dealing with longer movies...such as Pearl Harbor. Actually I used Dvd2one to combine the dual disks of PH and then used Rebuilder to do it's job, handle the interleaving/multi angles just fine and the output was perfect. I do not believe that Rebuilder should have any issues with these types of movies, yet Remake Pro and many other progs. can remove the unwanted angles and anything else prior to Rebuilder.
MovieDud -
Damn, that's a tough one, CrisCr0ss. I haven't been able to find any real answer for the problem. About all I can suggest is to enable "Special Error Processing" and then run the Rebuild Phase again. It seems to be related to having both a CELLID 0 and a VOBID 0. Note the last line in the log.
You're not the only one to have gotten that message, though:
http://forum.doom9.org/showthread.php?p=683859#post683859
I see you've already posted at the DVD-RB Forum, so maybe you'll get a better answer there. -
@CrisCrOss, friend I have seen that at other forums, but I have never experienced that error...I have had the run time error, but I uninstalled and reinstalled and it cleared up. I'm at AD a lot and they have a separate thread for Rebuilder and any issues. Have you checked there? I'll try to find something out and get back to you.
MovieDud -
thanks i will refrence this thread to the AD forums see if i can get some support
im going to try the latest version see how it turns out.
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 04:39 -
Trying to find what program to use for multiple angle editing
By greenlanternbatman in forum EditingReplies: 5Last Post: 1st Dec 2010, 15:22 -
Capturing the same source multiple times
By richieclare in forum Capturing and VCRReplies: 0Last Post: 6th May 2010, 11:10 -
Options for multiple formats from live source / ViewCast Osprey 210
By tomegdge in forum Capturing and VCRReplies: 0Last Post: 30th Apr 2010, 09:08 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 11:08
