I have a Toshiba DVD recorder. Using this recorder I have converted over a hundred Betamax tapes in my collection to DVDs. However, a handful of these tapes cannot be converted. When you play them into the DVD recorder what appears on the TV is a solid blue screen, just as if no video was coming in at all. When you fast forward the tape a picture does appear, and when you resume playing after the fast forward a good picture appears for just a moment.
The tapes themselves seem to be fine. I can play them directly to a TV and I have been able to make VHS copies of these tapes that work. I have tried using a SIMA Color Corrector to resolve this, as well as a device that is supposed to stabilize the picture to thwart copy protection. Neither one has had any effect.
Have you tried making DVD from the VHS copies? I used to have a lot of beta vcr's and when this happened it was usually cause by a damaged control track. You say you can watch them on your TV. Does your TV have an audio/video output? Try recording from the TV's output jacks.
Do you have more than one beta vcr? What your encountering could also be a speed problem. I would run into this problem if I tryed to watch a beta I tape on deck that did not support beta I playback. Some Sony vcr's had a switch on hte back panel to engage beta I playback. -
You probably need to clean the heads. Sounds like they're gunked up.
Without a good head cleaning solvent (denatured alcohol) and non-linting swabs, you could try a head cleaning tape with solution.
If "wet" cleaning isn't possible for you right now, a temporary "dry" cleaning procedure is to put the offending tape in, hit play, and then run it in fast scan for a while (so you can see the picture while FF) and then fast reverse scan for a while. You'll notice that the visible lines of noise will diminish as a percentage of screen real estate, while the clearer picture will increase.
Note: this is a temporary solution until you actually get your head (and possibly the tape) cleaned with a good wet system. This really just dislodges the packed-in magnetic particles for a while.
Have done this many, many times. Hope if works for you.
Scott -
This is probably a Macrovision (tm) problem. On most better Hi-Fi Beta Units, Macrovision copy protection was included. Symptoms include Blue screen, but video in fast forward and rewind when pluged to devices that accept macrovision like your dvd recorder.
Beta vcr's are immune from macrovision when recording. Retail beta tapes that include macrovsion would prevent a VHS vcr from copying.
The original post says he used a Sima SCC and a "stabilzer" so it seems unlikely this would be a macrovision problem. The Sima SCC has never failed to remove copy protection going to a vcr,of course with a DVD recorder you also have DCP. Few if any VHS tapes would have DCP and I doubt any beta tape would have it since production of beta pre-recorded tapes stopped before DCP existed. -
Originally Posted by wulf109
Recording from the TVs output jacks sounds interesting enough that I may try it eventually.
I do have more than one Beta VCR and this happens with both machines. The tapes in question are commercial tapes in Beta 2 format. -
I've also read where people have used the pass-through feature of a DV camcorder to get a Pioneer DVD recorder to not have a black screen when recording from some poor quality VHS tapes. That might be an option here.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
I have some betamax tapes
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 29th Dec 2009, 12:55 -
Again blue screen!!!
By alintatoc in forum ComputerReplies: 10Last Post: 10th Dec 2009, 14:16 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 06:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 08:56
