i have a movie that is split up into 2 files how do i burn them together? im going to be using nero
He's a liar and a murderer, and I say that with all due respect.
you may want to burn it first onto a RW disc. Most times when you join to files back together you get audio sync issues.
Google is your Friend -
I agree and disagree with sync issues. Agree- that joining before burning can cause sync issues. Disagree-that encoding each part on its own and then joining together does not.
So my tip would be to encode each half of the film separately, presumably you want mpeg2 (DVD compliant) format. Then simply join with your DVD Authoring program-TDA is ideal for a newbie upwards. And then burn with Nero or even with burner incorporated within TDA.
Note: CUE/BIN files are merely 'containers' for what is essentially inside them. 'Bin' being the container/bin with the file inside and 'Cue' quite literally being being the cue sheet for where to find the bin!
Extract each bin file-you'll probably end up with an avi or mpeg (mpeg1) file. Winrar can extract for you; also try VCDGear.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
