Hi, I just received an old IBM Intellistation Pro computer from a refurbished computer lab at my university.
It seems it was set up as a net boot computer at first and I can't get into the BIOS to enable CD or floppy booting since there is a password required to make any changes to the system.
Is there any way to reset this?
Unplug the computer, pull the BIOS battery for about 5 minutes, that will clear the BIOS and should remove the password protection. You will loose your BIOS settings back to default, but otherwise it should work fine.
BTW, did you try the word 'password'? You'd be suprised how often that's used.
If not the battery removal should work.
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 06:51 -
HELP changing default settings in Vegas
By TKB in forum Newbie / General discussionsReplies: 0Last Post: 16th Jun 2011, 00:04 -
Changing NAT Settings On The XBOX 360
By Nitro89 in forum Off topicReplies: 0Last Post: 8th Nov 2008, 11:49 -
changing wmv file settings
By gyvesk in forum EditingReplies: 1Last Post: 24th Mar 2008, 18:00 -
Changing DeVeDe default settings
By henrik.uggla in forum LinuxReplies: 0Last Post: 25th Jun 2007, 13:29
