I noticed that I get very poor audio quality, which is also out of sync with the video, when I directly source the audio(AC3) stream from an AVI file.
If I encode the VCD by first decompressing the audio stream(AC3) in the AVI to a separate WAV file and then source the audio from this separate WAV file, the resulting audio track on the VCD is very good quality and in sync with the video.
Am I missing some tuning that can be done to MainConcept Encoder that will bring the audio stream quality up to par when encoding a VCD directly sourcing both video(XVID) and audio(AC3) from an AVI?
If not, why is audio sourcing from a decompressed WAV file so much better than sourcing from an AVI? Or have I already answered my own question, the encoder has much less work to do when feeding it a decompressed WAV file?
Thanks in advance for your help. I'm just learning about video so I hope everyone understands me.
no tweaking you can do can fix this
Get it
If anything, the decoder (playback software/hardware device) is gonna determine why your .AC3 isn't quite as good as your uncompressed..
Since you're working with Xvid's and other people's techniques, you'll be at the mercy of their mistakes..
All your .WAV and .AC3 woes should go away, when you decide to go to the world of capturing video..
Everything is captured in .WAV, and every software should work with it no problem..
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
