I have imported into iMovie various DV movies from my mini-dv camera. These are lectures and that type of stuff. As I did not have a ‘boom’ mic or wireless mic the audio leaves something to be desired.
Is there a way to ‘extract’ the audio from the iMovie and amplify it and put it back in sync? Im not looking for Cinerama type work, just a better a better quality QT movie export where I can hear the lecture better.
Thanks rotuts
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Amplifying the audio will also make all the ambiant noise louder.
You can export the audio from iMovie, and with a high quality sound app, filter the ambiant noise, and boost the voice, and then save as AIFF and import back into iMovie.
In iMovie itself, with no exporting/importing involved, you can boost the volumn of the tack by clicking on the thin line that runs through the clip and moving it up, at the beginning of the clip and then at the end. You can see the percentage of audio increase in the little window at the base of the screen. But this will also boost the ambiant noise. -
Will
do you know of a sound app that will do this and how to do it?
thanks rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 01:40 -
Sony DCR-TRV9 mini DV cam, lots of dropouts, lose sync in iMovie
By lipwak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Oct 2010, 12:20 -
iMovie output to anything, no sound
By rikyo in forum ffmpegX general discussionReplies: 2Last Post: 6th Jan 2010, 09:13 -
Intermittent sound on mini-DV capture
By adamj_ut in forum Capturing and VCRReplies: 5Last Post: 17th Nov 2009, 18:47 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 04:53
