Hello I have a problem...my movie has LCPM sound but my player can't support it...
The problem is that eventhough I convert it into mpeg sound or similar it still is some kind of LCPM
How can I convert it right?
Thx
Results 1 to 9 of 9
With a DVD authoring program with AC-3 support. Most have it at least as an extra cost option.
What are you using?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Demux the audio and use BeSweet to convert it to AC3. You can find BeSweet at http://www.doom9.net in the Downloads section. Get BeSweet GUI because the GUI is easier to use than the command line.
Don't understand why you say your player can't support LPCM, as LPCM support is REQUIRED on EVERY DVD player.
Scott -
If your LPCM is 44KHz and you convert to 44KHz MPEG audio, that could be your problem. Make certain your audio is 48KHz for DVD compatibility.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
I don't remember seeing that in the specification. In fact, Region 1 DVD players are only required to support Dolby Digital to my knowledge. No MPEG audio, no LPCM. I could be wrong though.Don't understand why you say your player can't support LPCM, as LPCM support is REQUIRED on EVERY DVD player
Click on the What Is DVD link at the top left of this page:
This has always been, and still is, the NTSC standard for audio.Audio:
48000 Hz
32 - 1536 kbps
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
--Benjamin Franklin
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
ffdshow - AC3 or LCPM?
By AuroEdge in forum Software PlayingReplies: 6Last Post: 7th Nov 2007, 17:26 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
