This is maybe a silly question but... is it possible to convert DV material, filmed with a normal mini-DV camcorder, into HDV (High Definition Video) and then author the result to a DVD with any DVD author program (for instance, with DVD-lab (pro))? If yes, what is the software to be used?
Thanks,
Mário
It's a wasted effort if you expect to increase quality. You are only upscaling to a larger interlace raster at the same bitrate.*
Your HDTV will upscale to the monitors native format from a 480i input with realtime hardware.
In theory, a non-realtime 480i to progressive software conversion (for LCD or Plasma) may outperform the realtime HDTV scaler-deinterlacer but you may be facing days to weeks of computation with a PC.
* Vegas 6 will do it if you want.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2008, 13:05 -
is HDV right for me?
By ShBm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Apr 2008, 03:02 -
HDV to DV (4:3)
By PeterK in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Jul 2007, 11:21 -
From DV to HDV
By seven_deuce offsuit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Jul 2007, 19:15
