Results 1 to 12 of 12
    Sep 2005
    austria
    hello,
    my colleagues need sometimes videos in their powerpoint-presentations.
    until now I used ffmpegx to convert the different movies to vcd (mpeg1), because it don't use much processorpower during watching a movie and almost everybody can open mpeg1 (sometimes we need to give the movies to customers).
    I have two problems:
    since this year I mostly get dvd's from our partners. unfortunately ffmpegx can't directly convert .vob-files to vcd, I always get after 1 second an error message. so I use drop2dv to convert the .vob-file to a .dv file, because with dv I have no problems to convert it to vcd
    yesterday I tried for fun the new .h264 codec - what a great codec! I also noticed, that with .h264 I can directly convert .vob-files - is there a chance, that I can to this vcd, too?
    furthermore I noticed, that after converting the .vob file to .dv with drop2dv, the quality is declined, the dv-file is (watched with quicktime-player) not as sharp as the original .vob file (watched with vlc) or the .h264 file (watched with quicktime-player)
    any experience, if this is a commom problem or a problem of drop2dv?
    second question:
    for converting to vcd I use the standard-resolution of 352x288, but my colleagues would like to have a larger resolution. if I use the typical resolution of a dvd, I get promptly an error message or during conversion.
    is it possible to mpeg1 with other resolution than 352x288?
    many thanks for your help in advance!
    ferdinand
  2. Originally Posted by indy27
    It can. If you get an error, please post the process output (blue "i" icon in the progress window).
    Yes, but it will be then playable only on a computer. Just change the resolution and use "XVCD" profile in the options tab, instead of "VCD".
    Sep 2005
    austria
    hello,
    thanks for your reply, here is the error message:
    Encoding started on Mon Sep 26 19:25:55 CEST 2005
    /bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Permission denied
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
    example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
    example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
    **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
    best regards,
    ferdinand
  4. The second line seem to show a permission error on mpeg2enc. Try to remove /Library/Application Support/ffmpegX/ and reinstall by making sure that you're logged in OSX with an administrator account.
    Sep 2005
    austria
    hello,
    sorry, no luck:
    Encoding started on Mon Sep 26 19:42:17 CEST 2005
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    the second error message is strange - I checked in singleuser-mode with fsck my harddisk and repaired permissions - no problems found
    and here the user-rights of the library-folder:
    drwxrwxrwx 18 root admin 612 Sep 26 19:41 ./
    drwxrwxr-x 16 root admin 544 Sep 26 19:41 ../
    -rw-r--r-- 1 admincln staff 6148 Jul 18 2004 .DS_Store
    -rwxr-xr-x 1 admincln admin 281028 May 15 2004 gocr*
    -rw-r--r-- 1 admincln admin 500 May 15 2004 gocrfilter_en.sed
    -rw-r--r-- 1 admincln admin 361 May 15 2004 gocrfilter_fr.sed
    -rw-r--r-- 1 admincln admin 271 May 15 2004 gocrfilter_nl.sed
    -rw-r--r-- 1 admincln admin 67 May 15 2004 gocrfilter_none.sed
    -rwxr-xr-x 1 root admin 7390448 Sep 26 19:41 mencoder*
    -rwxr-xr-x 1 admincln staff 244832 May 15 2004 mp2enc*
    -rwxr-xr-x 1 root admin 188524 Sep 26 19:41 mpeg2enc*
    -rwxr-xr-x 1 root admin 7304968 Sep 26 19:41 mplayer*
    -rwxr-xr-x 1 admincln admin 22596 May 15 2004 subtitle2pgm*
    -rwxr-xr-x 1 admincln staff 286168 Jul 18 2004 tcextract*
    -rwxr-xr-x 1 admincln staff 589400 May 15 2004 vcdxbuild*
    -rwxr-xr-x 1 admincln staff 568908 May 15 2004 vcdxgen*
    -rwxr-xr-x 1 admincln staff 113352 May 15 2004 yuvdenoise*
    -rwxr-xr-x 1 admincln staff 314968 May 15 2004 yuvscaler*
    best regards,
    ferdinand
  6. The permission error is gone. The error which keeps showing means that 1/ you enabled the 'Decode with Quicktime' option, AND 2/ your Quicktime Player cannot open your source file (is it mpeg-2?).
    Sep 2005
    austria
    hello,
    yes, it's a .vob-file and so mpeg2.
    yes, quicktime was activated, so I changed to vcd ffmpegx and deactivated the quicktime-function and now he starts.
    unfortunately after a few minutes a get the following error message:
    Encoding started on Mon Sep 26 22:51:35 CEST 2005
    Input #0, mpeg, from '/Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB':
    Duration: 00:03:34.3, start: 0.287267, bitrate: 6127 kb/s
    Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x576, 25.00 fps, 4500 kb/s
    Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
    Stream #0.2[0x81]: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
    Output #0, rawvideo, to '/Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB.ff.mpv':
    Stream #0.0: Video: mpeg1video (hq), yuv420p, 688x512, 25.00 fps, q=2-20, 3956 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    [mpeg1video @ 0x4199e0]rc buffer underflow
    bench: utime=278.756s
    video:104055kB audio:0kB global headers:0kB muxing overhead 0.000000%
    Output #0, wav, to '/Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB.ff.wav':
    Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0 [sync #0.0]
    video:0kB audio:37094kB global headers:0kB muxing overhead 0.000116%
    Computing levels...
    UNDEFINED.VOB.ff. --% done, ETA --:--:-- (batch 0% done, ETA 99:14:08)
    UNDEFINED.VOB.ff. 1% done, ETA 00:00:00 (batch 1% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 2% done, ETA 00:00:00 (batch 2% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 3% done, ETA 00:00:00 (batch 3% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 4% done, ETA 00:00:00 (batch 4% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 5% done, ETA 00:00:00 (batch 5% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 6% done, ETA 00:00:00 (batch 6% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 7% done, ETA 00:00:00 (batch 7% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 8% done, ETA 00:00:00 (batch 8% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 9% done, ETA 00:00:00 (batch 9% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 10% done, ETA 00:00:00 (batch 10% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 11% done, ETA 00:00:00 (batch 11% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 12% done, ETA 00:00:00 (batch 12% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 13% done, ETA 00:00:00 (batch 13% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 14% done, ETA 00:00:00 (batch 14% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 15% done, ETA 00:00:00 (batch 15% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 16% done, ETA 00:00:00 (batch 16% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 17% done, ETA 00:00:00 (batch 17% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 18% done, ETA 00:00:00 (batch 18% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 19% done, ETA 00:00:00 (batch 19% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 20% done, ETA 00:00:00 (batch 20% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 21% done, ETA 00:00:00 (batch 21% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 22% done, ETA 00:00:00 (batch 22% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 23% done, ETA 00:00:00 (batch 23% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 24% done, ETA 00:00:00 (batch 24% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 25% done, ETA 00:00:00 (batch 25% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 26% done, ETA 00:00:00 (batch 26% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 27% done, ETA 00:00:00 (batch 27% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 28% done, ETA 00:00:00 (batch 28% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 29% done, ETA 00:00:00 (batch 29% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 30% done, ETA 00:00:00 (batch 30% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 31% done, ETA 00:00:02 (batch 31% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 32% done, ETA 00:00:02 (batch 32% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 33% done, ETA 00:00:02 (batch 33% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 34% done, ETA 00:00:02 (batch 34% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 35% done, ETA 00:00:02 (batch 35% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 36% done, ETA 00:00:02 (batch 36% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 37% done, ETA 00:00:02 (batch 37% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 38% done, ETA 00:00:02 (batch 38% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 39% done, ETA 00:00:02 (batch 39% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 40% done, ETA 00:00:01 (batch 40% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 41% done, ETA 00:00:01 (batch 41% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 42% done, ETA 00:00:01 (batch 42% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 43% done, ETA 00:00:01 (batch 43% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 44% done, ETA 00:00:01 (batch 44% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 45% done, ETA 00:00:01 (batch 45% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 46% done, ETA 00:00:01 (batch 46% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 47% done, ETA 00:00:01 (batch 47% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 48% done, ETA 00:00:01 (batch 48% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 49% done, ETA 00:00:01 (batch 49% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 50% done, ETA 00:00:01 (batch 50% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 51% done, ETA 00:00:01 (batch 51% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 52% done, ETA 00:00:01 (batch 52% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 53% done, ETA 00:00:01 (batch 53% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 54% done, ETA 00:00:01 (batch 54% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 55% done, ETA 00:00:01 (batch 55% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 56% done, ETA 00:00:01 (batch 56% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 57% done, ETA 00:00:01 (batch 57% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 58% done, ETA 00:00:01 (batch 58% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 59% done, ETA 00:00:01 (batch 59% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 60% done, ETA 00:00:01 (batch 60% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 61% done, ETA 00:00:01 (batch 61% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 62% done, ETA 00:00:01 (batch 62% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 63% done, ETA 00:00:01 (batch 63% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 64% done, ETA 00:00:01 (batch 64% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 65% done, ETA 00:00:01 (batch 65% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 66% done, ETA 00:00:01 (batch 66% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 67% done, ETA 00:00:00 (batch 67% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 68% done, ETA 00:00:00 (batch 68% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 69% done, ETA 00:00:00 (batch 69% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 70% done, ETA 00:00:00 (batch 70% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 71% done, ETA 00:00:00 (batch 71% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 72% done, ETA 00:00:00 (batch 72% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 73% done, ETA 00:00:00 (batch 73% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 74% done, ETA 00:00:00 (batch 74% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 75% done, ETA 00:00:00 (batch 75% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 76% done, ETA 00:00:00 (batch 76% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 77% done, ETA 00:00:00 (batch 77% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 78% done, ETA 00:00:00 (batch 78% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 79% done, ETA 00:00:00 (batch 79% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 80% done, ETA 00:00:00 (batch 80% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 81% done, ETA 00:00:00 (batch 81% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 82% done, ETA 00:00:00 (batch 82% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 83% done, ETA 00:00:00 (batch 83% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 84% done, ETA 00:00:00 (batch 84% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 85% done, ETA 00:00:00 (batch 85% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 86% done, ETA 00:00:00 (batch 86% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 87% done, ETA 00:00:00 (batch 87% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 88% done, ETA 00:00:00 (batch 88% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 89% done, ETA 00:00:00 (batch 89% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 90% done, ETA 00:00:00 (batch 90% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 91% done, ETA 00:00:00 (batch 91% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 92% done, ETA 00:00:00 (batch 92% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 93% done, ETA 00:00:00 (batch 93% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 94% done, ETA 00:00:00 (batch 94% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 95% done, ETA 00:00:00 (batch 95% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 96% done, ETA 00:00:00 (batch 96% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 97% done, ETA 00:00:00 (batch 97% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 98% done, ETA 00:00:00 (batch 98% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 99% done, ETA 00:00:00 (batch 99% done, ETA 00:00:00)
    UNDEFINED.VOB.ff. 100% done, ETA 00:00:00 (batch 100% done, ETA 00:00:00)
    Applying adjustment of 9.30dB to /Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB.ff.wav...
    UNDEFINED.VOB.ff. 3% done, ETA 00:00:32 (batch 3% done, ETA 00:00:32)
    UNDEFINED.VOB.ff. 4% done, ETA 00:00:24 (batch 4% done, ETA 00:00:24)
    UNDEFINED.VOB.ff. 5% done, ETA 00:00:19 (batch 5% done, ETA 00:00:19)
    UNDEFINED.VOB.ff. 6% done, ETA 00:00:16 (batch 6% done, ETA 00:00:16)
    UNDEFINED.VOB.ff. 7% done, ETA 00:00:13 (batch 7% done, ETA 00:00:13)
    UNDEFINED.VOB.ff. 8% done, ETA 00:00:11 (batch 8% done, ETA 00:00:11)
    UNDEFINED.VOB.ff. 9% done, ETA 00:00:10 (batch 9% done, ETA 00:00:10)
    UNDEFINED.VOB.ff. 10% done, ETA 00:00:09 (batch 10% done, ETA 00:00:09)
    UNDEFINED.VOB.ff. 11% done, ETA 00:00:08 (batch 11% done, ETA 00:00:08)
    UNDEFINED.VOB.ff. 12% done, ETA 00:00:07 (batch 12% done, ETA 00:00:07)
    UNDEFINED.VOB.ff. 13% done, ETA 00:00:07 (batch 13% done, ETA 00:00:07)
    UNDEFINED.VOB.ff. 14% done, ETA 00:00:06 (batch 14% done, ETA 00:00:06)
    UNDEFINED.VOB.ff. 15% done, ETA 00:00:06 (batch 15% done, ETA 00:00:06)
    UNDEFINED.VOB.ff. 16% done, ETA 00:00:05 (batch 16% done, ETA 00:00:05)
    UNDEFINED.VOB.ff. 17% done, ETA 00:00:05 (batch 17% done, ETA 00:00:05)
    UNDEFINED.VOB.ff. 18% done, ETA 00:00:05 (batch 18% done, ETA 00:00:05)
    UNDEFINED.VOB.ff. 19% done, ETA 00:00:04 (batch 19% done, ETA 00:00:04)
    UNDEFINED.VOB.ff. 20% done, ETA 00:00:04 (batch 20% done, ETA 00:00:04)
    UNDEFINED.VOB.ff. 21% done, ETA 00:00:04 (batch 21% done, ETA 00:00:04)
    UNDEFINED.VOB.ff. 22% done, ETA 00:00:04 (batch 22% done, ETA 00:00:04)
    UNDEFINED.VOB.ff. 23% done, ETA 00:00:03 (batch 23% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 24% done, ETA 00:00:03 (batch 24% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 25% done, ETA 00:00:03 (batch 25% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 26% done, ETA 00:00:03 (batch 26% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 27% done, ETA 00:00:03 (batch 27% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 28% done, ETA 00:00:03 (batch 28% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 29% done, ETA 00:00:02 (batch 29% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 30% done, ETA 00:00:02 (batch 30% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 38% done, ETA 00:00:03 (batch 38% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 39% done, ETA 00:00:03 (batch 39% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 40% done, ETA 00:00:03 (batch 40% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 41% done, ETA 00:00:03 (batch 41% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 42% done, ETA 00:00:03 (batch 42% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 43% done, ETA 00:00:03 (batch 43% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 44% done, ETA 00:00:03 (batch 44% done, ETA 00:00:03)
    UNDEFINED.VOB.ff. 45% done, ETA 00:00:02 (batch 45% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 46% done, ETA 00:00:02 (batch 46% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 47% done, ETA 00:00:02 (batch 47% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 48% done, ETA 00:00:02 (batch 48% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 49% done, ETA 00:00:02 (batch 49% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 50% done, ETA 00:00:02 (batch 50% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 51% done, ETA 00:00:02 (batch 51% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 52% done, ETA 00:00:02 (batch 52% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 53% done, ETA 00:00:02 (batch 53% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 54% done, ETA 00:00:02 (batch 54% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 55% done, ETA 00:00:02 (batch 55% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 56% done, ETA 00:00:02 (batch 56% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 57% done, ETA 00:00:02 (batch 57% done, ETA 00:00:02)
    UNDEFINED.VOB.ff. 67% done, ETA 00:00:01 (batch 67% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 68% done, ETA 00:00:01 (batch 68% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 69% done, ETA 00:00:01 (batch 69% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 70% done, ETA 00:00:01 (batch 70% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 71% done, ETA 00:00:01 (batch 71% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 72% done, ETA 00:00:01 (batch 72% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 73% done, ETA 00:00:01 (batch 73% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 74% done, ETA 00:00:01 (batch 74% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 75% done, ETA 00:00:01 (batch 75% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 76% done, ETA 00:00:01 (batch 76% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 77% done, ETA 00:00:01 (batch 77% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 78% done, ETA 00:00:01 (batch 78% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 79% done, ETA 00:00:01 (batch 79% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 80% done, ETA 00:00:01 (batch 80% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 81% done, ETA 00:00:01 (batch 81% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 82% done, ETA 00:00:01 (batch 82% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 83% done, ETA 00:00:01 (batch 83% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 84% done, ETA 00:00:01 (batch 84% done, ETA 00:00:01)
    UNDEFINED.VOB.ff. 85% done, ETA 00:00:01 (batch 85% done, ETA 00:00:01)
    Input #0, wav, from '/Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB.ff.wav':
    Duration: 00:03:35.3, start: 0.000000, bitrate: 1411 kb/s
    Output #0, mp2, to '/Users/adminclnt/Desktop/film5/UNDEFINED/VIDEO_TS/UNDEFINED.VOB.ff.mp2':
    Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    video:0kB audio:5888kB global headers:0kB muxing overhead 0.000000%
    **ERROR: [mplex] Too many frame drops -exiting
    do you have a tip to solve this problem?
    ferdiannd
  8. Did you use "XVCD" profile in the options tab?
    Sep 2005
    austria
    hello,
    yes, I tried vcd ffmpeg and vcd mpeg2enc - with both I got error messages.
    please find enclosed both settings that I used and the error-messages.
    it would be great, if I can use vcd ffmpeg because here I can use the crop-feature, but ffmpeg does not have "xvcd"
    many thanks for your help!
    regards,
    ferdinand
    Sep 2005
    austria
    i think, the attachment is missing in my previous post
    logssettings.zip
  11. I tried with your mpeg2enc profile (using 'Decode with Quicktime') and I obtained a successful encoding. Try encoding with a short clip to see if it changes anything, or email me a link to your source file so as I can download it and reproduce your error on my computer.
    Sep 2005
    austria
    hello,
    now it works! I used vcd ffmpeg (without "use quicktime"), my fault was to activate the "deinterlace"-feature. after deactivating I had no problems to convert the .vob-file to mpeg1 with dvd resolution.
    thanks for your great support!
    best regards,
    ferdinand
