Could someone clarify to a newbie what the difference is between these two, and what is the purpose of each one.
Do you have to convert an AVI to Mpeg to burn to DVD?
For example should I capture my file to Pinnacle Studio in AVI, edit it, and export it as an Mpeg ready to burn to DVD?
I'm asking as I am having so many problems burning a DVD with an AVI file. (I've already had that question addressed here)
Sorry, I should expand my question.Originally Posted by yoda313
I want to get the best possible quality for my burned DVD.
Is it better to burn an AVI rather than an MPEG2 ? -
If you don't plan on doing any editing or modifying of the movie, go ahead and convert directly to mpeg2. If you want to do any changes, capture as avi. Your quality will depend on the hardware and software that you use. I highly recommend that you do some reading the guides and tutorials in this forum before you get too far along. It will be well worth it.
Rob -
You can't burn an avi as a dvd unless you're talking about divx for a divx player. It will have to be mpeg2 to be burnable by a dvd authoring program.Originally Posted by didikai
Many here use avi then convert to mpeg2. I personally can't because my wintv pvr250 only records in mpeg. I love my results and I don't like doing more work then I have to. If you want it easier capture in mpeg and then author your dvd. If you want to edit it more and throw in some filters and stuff capture in avi and then convert to mpeg. Either way your finished file has to be in mpeg2 if your making a standard dvd.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
