I was lent a DVD in Greece which had been made by the hotel owner. I could play it on my iBook but when I tried to Toast a copy of it, Toast stalled about a quarter way in and the internal drive simply buzzed and clicked until I forced it to quit. (I've had this happen previously with scratched discs). I cleaned and polished the disc but copying failed.
However, I was able to copy the folders AUDIO_TS and VIDEO-TS.
Is it possible to reconstruct the DVD from this? AUDIO_TS is empty while VIDEO-TS contains three VIDEO files and three VTS files.
Martin
Results 1 to 9 of 9
I'm not a mac user but this is a dvd question.
Yes the video_ts folder IS the dvd. The audio_ts is supposed to be empty.
Simply burn the dvd with the video_ts folder and the audio_ts folder as the MAIN directories.
D:\
video_ts
audio_ts
Then it will work just fine.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
So I simply set Toast to burn a DVD and drag these two folders into the window?
OK, I'll try that. -
Make sure you select DVD-ROM (UDF) and hit New Disc before dragging the two *****_TS folders in.
In the Data tab, click the little bluish drawer button on the upper left hand side to make the drawer come out and then select the Advanced tab in the drawer. The DVD-ROM (UDF) option will now be available.
Don't forget to hit New Disc before adding your folders or it's coaster #2
By version 6.0.9 Roxio had made a few changes to Toast 6.
To do you want you want you can either use the DVD-ROM option in Data tab, or the DVD from VIDEO_TS folder in the Video tab. If you choose the latter, Toast will automatically add an empty AUDIO_TS folder, and filter out any Mac hidden files that the OS may have added to your folder.
Also, you no longer need to hit New Disc when using the DVD-ROM option - Toast will do that too. -
Yay, thanks ffooky, it worked!
Where do I send the munny?
Thanks macuser25 for the update. Too late but duly noted!
What nice people you are, here.
Martin -
Martin, have you tried MacTheRipper on the DVD? If you can
play it, MTR might well be able to put the files on your HD in
useful form. Then compress as needed and burn a copy.
AVI to DVD -didn't get video_ts or audio_ts
By Ursula514 in forum ffmpegX general discussionReplies: 5Last Post: 8th Jan 2011, 15:31 -
Deconstructing, translating, then reconstructing an animated menu
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2009, 18:06 -
HELP!!. . .DVD Without AUDIO_TS Folder???!!!!
By sniperloc in forum Authoring (DVD)Replies: 13Last Post: 17th Feb 2009, 13:29 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 12:34 -
Reconstructing a subtitled movie
By ker-plop in forum MacReplies: 0Last Post: 26th Aug 2007, 16:19
