I’ve been going over all the capture card options I can find for a Powerbook (I have a G3 400 and a G4 1.67).
My primary purpose is to capture PAL VHS and convert to DVD. I like the sound of DV converters rather than hardware encoders as I prefer flexibility in encoding stuff, even if it takes longer (unless someone talks me into a hardware encoder being much better!).
While I liked the sound of the DAC-100 or ADVC-100 on Ebay ranging from $150-$250, I found a Formac Studio TVR for US$130 second hand which sounds like it will do the same job. I guess the TV tuner is a bit of a gimmick in the sense that you could just plug your VCR tuner into the DAC-100 AV ports and get the same result.
Anyway, I’ve read a lot of hatemail* about the Formac Studio, so I had a few questions for those in the know
- are the Studio’s DV importing results similar to the DAC-100 or ADVC-100
- is the criticism of the Formac related to the TV capture software rather than DV conversion hardware performance?
- did the Studio ever come with firmware 1.05 – I heard that caused audio noise issues and had to be updated at the factory
- does a Powerbook Pismo or Powerbook 1.67 firewire bus provide enough power without the separate power pack – Formac says some Powerbooks don’t, but not which ones.
- how long does it take to encode an hour of DV to MPEG-2 on a Powerbook G4 1.67?
I’d really appreciate suggestions.
Regards,
Bruce
Results 1 to 1 of 1
Honestech TVR software crashes my computer
By anbarasan in forum Capturing and VCRReplies: 0Last Post: 2nd Dec 2011, 23:56 -
Honestech TVR Troubleshoot
By alimech in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2011, 23:56 -
Anyone Own 101 Tips & Tricks For Sony Movie Studio?
By V Bot in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2011, 20:43 -
Hardware Requirements for TVR?
By WDude in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2007, 15:41 -
What is better quality wise?
By chrishallowell in forum Capturing and VCRReplies: 9Last Post: 27th Aug 2007, 15:24
