I've got a linksys router (befsx41) and it's just horrible. I've always had problems with firmware being insanely unstable and for the last week or so, AIM has been knocking me off every five minutes or so. Also, it won't work properly with Azureus or other programs. Does anyone have any advice/current deals on a good wireless router (or switch) with a built in hardware firewall? Specifically, not a linksys.
Any advice would be appreciated.
Results 1 to 11 of 11
Is there that much difference between the R and the X models? The BEFSR41 I had was solid as a rock for years. I suspect I could dig it out of the mothballs and it would still work like a champ.
flonk! -
Dilbert, don't go dlink if your doing ANY wireless. I've not horrible problems with their wireless equipment.
That being said I've had good luck with Linksys in the past, but if your convinced its a programming issues instead of a issue with your specific router I'd suggest SMC or Netgear. -
I have a wireless Linksys router I bought a year ago and it still works like a champ....could be a programming issue you're having or something.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Well, maybe it's just that linksys sucks on a case by case basis. I just know that a lot of other people have had problems with the model I've got- and I really didn't want to dump $80 to a $100 on something that will develop the same problems. Any of you linksys guys use Port Forwarding or any of those features successfully on your boxes?
"Out of order, I'll show you out of order! You don't know what out of order is Mr. Trask! I'd show you but I'm too old, I'm too tired, and I'm too f--kin' blind. If I were the man I was five years ago I'd take a flame-thrower to this place!" -
Ditto... I've got the same one and it is very stable.Originally Posted by Mister Flonk-Flonk
Both port forwarding and port triggering (depending on the app) without issue. Dilbert, if you haven't done so, check here:
http://www.portforward.com/english/routers/port_forwarding/Linksys/BEFSX41/BEFSX41index.htm
Step by step.
BTW, the AIM issues you're having sounds like the lease time for DHCP is set too short on your router. As for Azureus, I had an issue where it would lock my computer. Without it running, my computer could run for days without being bogged down by anything. Start Azureus, it would freeze within an hour. Turned out it was the Java build I was using. Try updating and see what happens. I'm not sure if it still holds true, but I remember a lot of torrent sites did not like Azureus anyway, you may want to look into BitTornado. -
I have a wired Linksys and a wireless Netgear. Both have worked fine for years now.
I threw in the towel and purchased a WRT56G, so far so good.
I have nothing but good experiences with Linksys and nothing but bad experiences with D-Link......go figure.
I just got a Netgear WGR614 from Circuit City for $30. It was one of last weekends specials and I used an order online pick it up in the store options. Now i just gotta pick it up.
I wish I could afford 2 because I have a use for another.
How Can I Set-Up the Linksys Wireless Router??
By Frank-0-Video in forum ComputerReplies: 9Last Post: 27th Feb 2009, 16:18 -
Linksys WRT160N, cant get apps to access internet
By logannsan in forum ComputerReplies: 3Last Post: 19th Feb 2009, 10:36 -
region free for linksys dma2200
By culohuevo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Dec 2008, 11:43 -
Help setting up the storage link from my Linksys WRT350N
By ryangarfield in forum ComputerReplies: 0Last Post: 22nd Aug 2008, 17:21 -
Linksys WRT54GX4 router problem
By SIRCOOKS in forum ComputerReplies: 9Last Post: 19th Feb 2008, 11:40
