  1. Member NoFace's Avatar
    Jan 2005
    wherever I am
    I've been using dvdshrink (v103, though I've tried 23 and 3.1) to back-up my kids' dvds. I wanted to eliminate the tedious navigating through all the warning screens, trailers, and look-at-how-amazing-our-menus-are menu intros, while my 3 yr. old waits as patiently as a 3 yr. old can, which is not at all. v103 is great, because its really easy, just pick the biggest vob, check with the slider, and away you go. Now the fact that your kid knows what the eject button does isn't quite as financially challenging.
    However, when the back-up starts to play, inevitably I get the director's comment audio, along with subtitles (which, while she's advanced, my 3 yr. old doesn't quite need, yet.) So, I still have to sit there with the remote and change all the settings. Kinda defeats the purpose.
    Is there a way to edit the ifo once it's ripped, to tell the player what the audio and sub preferences are? The guides I've read through so far haven't directly addressed this issue. Can anyone tell me, or suggest a guide? I don't mind working a bit, or learning new software. Thanks.
    occasionally larger than 255 characters
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    In dvdshrink you can eliminate subtitles and audio commentary. All you want checked is either the main 5.1 audio track or 2.0 stereo (if its not in digital surround sound). You can have the dvd reauthored with just the movie and only one audio track. The chapter marks will still be intact though.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The first thing I'd do is update to the last version of DVDShrink (3.2 AFAIK). It has a preview so that you can test the audio streams one by one to make sure you're getting the right one, and of course you can just use reauthor mode to only get the main feature, and untick the other unwanted audio and subtitles.
    If in doubt, Google it.
  4. Member NoFace's Avatar
    Jan 2005
    wherever I am
    OK, as far as the subs, it was a "DUH!" moment, in that i'm usually backing up my anime, in which subs can be important for a non-japanese speaking person such as myself, so thanks, Yoda. "Idiot you were, show many others I will."
    As far as updating shrink (I would imagine that 3.2 is the last? Ever?), I hope that'll work. I noticed when backing up anime in 3.1 that even if I had un-ticked the english audio (leaving only the japanese audio), and started the preview window, it would still play the english audio track (which I presume is the default). Jimmalenko, is there a trick for checking audio streams, or is it evident in the latest shrink how to do so?
    Apr 2003
    Largo, FL
    When you reauthor, after you drag the main movie into the reauthor section, right click on the movie and select 'Set Default Streams'. It'll let you set which audio you want it to start with. It'll also let you select a subtitle set to default to for that disk.
  6. Member NoFace's Avatar
    Jan 2005
    wherever I am
    Sweet! Thank you, BobK. I love this website.
