hi. i have an avi about 25 minutes long and about 240mb. the quality is outstanding. i also have some subtitles in both srt, ssa format. my problem is i need a program i can hardcode the subtitles with and at the same time, keep the quality of it. can anyone tell me what program to use and how to keep the quality. i used virtualdub and it worked but the avi cam out 150mb when i saved it as xvid and even less when i saved it as divx. maybe im not setting the settings right or maybe im not using the best program. can u guys show me the way. also when i do get the subs done, can i burn it just like it is so i can watch it in my dvd. TY in advance.
Results 1 to 12 of 12
Use VirtualDub, Xvid codec, single pass, Quantization mode, with a target quantizer of 2 or 3.
Ok i did exactly what u said and bingo. the original was about 250mb and when i did it your way, it came out to be 201mb and i impressed because the outcome look as good if not better than the original. TY very much. i really appriciate it.
Glad to hear it worked out. At Q=2 the result will be almost identical to the source. At Q=3 there will be a little macroblocking but you won't notice at normal playback speeds.
Speaking of macroblocking, your source probably has some (you may have to look at enlarged still frames to really see it). Adding MSU's Deblocking filter (before adding subtitles in the filter chain) will repair a lot of it. That might get you even better results. -
the macroblocking is not even visible to the human eye but i stll want to try using it jus to experiment. could you show me how to use it . TY very much. youve been a HUGE help. ive been working on this project for like a year now lol and now i can finish it. TY
Just download the MSU Deblocking filter:
http://www.compression.ru/video/deblocking/index_en.html
and put the vdf file in VirtaulDub's plugins folder.
Use Video -> Filters... -> Add... to add the filter before any other filters. The default settings are usualy fine (high quality, U deblock, V deblock). Otherwise the procedure is the same as you used before. -
Hi again. When this project was all done, i burned it as data and when i put it in my dvd player. it didnt recognize the cd. Why would thid be?
If your DVD player can't play avi (divx) then you have to convert to mpeg2 and author a dvd. If you only have a cd writer then you can make vcd or svcd.Originally Posted by mlo356
Also encoding at a low fixed quant could lead to bitrate spikes on a player that can play MPEG4/AVI's.
mlo356 in the future please only post your problem once instead of 3 times.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
