Hello everyone, i'm extracting a .bin file, i used IOSbuster, then I used TMPGenc DVD Author to conver thte .mpg to dvd format. But when i add the track i get the following 2 errors:
The video framerate 23.976 fps cannot be used for a standard DVD, it must be 29.97fps, i realize this, but can't it be changed? Also, it says the VIDEO GOP is too long. For a standard dvd it is necessary that the GOP fulfil the following condition: Max 36 fields (18 frames) NTSC format, pal format 15. Is there anyway for me to fix this or am i screwed? It won't let me ignore the errors either.
Thanks! But i don't understand when they say "patch it" how do u patch somthing to change the frame rate? Also will that fix my GOP?
thanks but when i downloaded it and tried to load the .mpg or .bin it says file must be an elementary stream when i try to convert
Uknown DVD - Is First play track the problem (TMPGEnc Author Works 4)
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2011, 06:26 -
I want to add an audio track to a DVD.
By Nagashi in forum Authoring (DVD)Replies: 7Last Post: 14th Apr 2010, 20:39 -
Question how to add subtitles with TMPGEnc DVD Author 3
By jimdagys in forum SubtitleReplies: 1Last Post: 5th May 2008, 17:24 -
"Non valid Key" in GUI for DVD Author
By Harry Cover in forum Authoring (DVD)Replies: 1Last Post: 11th Nov 2007, 14:35 -
Add a commentary track to A DVD
By R3bel in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 08:42
