Hi i just had a second harddrive installed on my computer and it reads my transfer rate at 2mb per second instead of forty.Even when i am listening to stream it bogs out when i am even making a download.yesterday it took ten minutes to transfer five mp3 to it.Is there a setting that maty be off
your drive may be stuck on pio. Have you checked this under device manager?
and what sort of drive is it? sata or pata?Some people are only alive because it may be illegal to kill them -
i went in device manger and tried to switch to dma mode but it will not move from pio mode.
Try uninstalling the IDE channel that the drive is connected to in Device Manager. Reboot and the OS will replace it and that usually resets it to DMA mode.
i did the uninstall and it was in dma mode but is still very slow.I went to pc stop and did a test which stated the second harddrive has a transfer rate of two mbs per second instead of fourty.
hmmm.... please read the following sticky:
https://www.videohelp.com/forum/viewtopic.php?t=187112
XP can be very stuborn though.... so bring out the big guns and get into you registry:
http://sniptools.com/vault/getting-back-to-dma-mode-in-windows-xp.htm
Following is the mechanism that has worked for me, please try it at your own risk, it involves hacking the registry:
1. Open RegEdit
2. Find the following KEY:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\ Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\000x
3.The last four digits will be 0000, 0001, 0002, 0003, and so on.
4.Under each key, delete all occurences of the following values:
MasterIdDataChecksum
SlaveIdDataChecksum
5. Reboot the computer. Windows will now redetect DMA settings.
Once I tried the "un-install IDE chanel" trick 5 times... no luck. Primary IDE was in PIO and would not reset to DMA. Used the registry tweak and BAM... DMA all around!
JSB
PS please try it at your own risk, it involves hacking the registry!
JSB -
If it's in DMA mode and it's still that slow, check the drive to make sure the jumpers are set correctly to slave or master. Try a different IDE cable. Make sure it's a 80 conductor version. Try it on a different IDE channel to see if your hard drive controller has a problem. If all that fails, maybe something wrong with the drive.
Slow video progression rate after conversion
By mohit in forum Video ConversionReplies: 2Last Post: 8th Feb 2009, 12:19 -
slow wireless tranfer speed
By Eyecan'tcode in forum ComputerReplies: 16Last Post: 9th Jun 2008, 21:30 -
Slow Frame Rate
By tobymac in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Mar 2008, 14:12 -
Slow Read Rate
By mr240 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 18:41 -
Tranfer DV from SONY DCR-PC7 via Firewire to computer
By riverdaleDV in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 12:10
