First, I have about 4 mpg videos (one of em in PAL VCD format) that I cannot change anything using tmpgenc.. I get an ilegal decimal point calculation error or sumfin...
I read that if that error happened, to try and use virtualdub to convert the audio into .wav and try to use only the video source on tmpgenc.. well, that didn't work for any of those 4 mpegs..
Also, I tried to convert some .mov files to .mpg, but I get no sound.. virtualdub doesn't work with .mov, and total recorder 3 didn't work well, believe me.
thanks for the help.
This means you've got bad frames in your mpeg. You'll have to cut the bad ones out and then encode.
I only dream in black & white...
MSN: paschendale@gmail.com
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 10:32 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 12:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
