All of a sudden avi files that have been converted to DVD are over 4.5GB
I have set the manual size to as low as 3.9GB but they still come out over 4.5GB???
doesent that compress the file again?
I would prefer to to only compress 1 time for best quality -
You would not notice any difference in quality, because the compression would be very slight.
When similar thing happens to me - I use DVD Shrink.
I understand what you would prefer, but I think that you do not have a choice in this particular case. -
DivxtoDVD seems to work best when you don't change it's default values. It uses the original compression statistics to create the new mpeg2 version. Usually this results in remarkedly small files sizes for quality comparable to the original avi file. It also means that it is less likely to reach a given target size. It is a single pass variable bitrate encoder, and predicable outcomes are not something this type of encoder is known for (this holds for most one-pass VBR encoders, it is inherent in the method). If you want to be able to control the output size with some degree of accuracy you will have to learn how to use the basic tools to do this yourself. This included correctly encoding with a good standalone encoder, and authoring with an authoring tool. This need not be daunting, as both tmpgenc plus and tmpgenc DVD Author are easy to use, capable tools for the beginner.
Read my blog here.
Actually, if used correctly the quality from tmpgenc may even be higher than the original as you can apply filters as you encode. Or you can use virtualdub or avisynth to clean up the image and frameserve to tmpgenc. I use CCE and often frameserve to it to produce output better than the original.
But you are correct that it won't be as fast as DivxtoDVD. That is the price you pay for quality. As for AC3, you can get an encoder for tmpgenc / TDA that encodes to 2.0 AC3. If you have AC3 audio to begin iwth you can strip it out with virtualdub and use later when you author.
Out of curiosity, what was the combined runtime of the 'too large' disk ?Read my blog here.
Reformatted..now all output videos with XMediaRecode are too large
By smackyourfupa in forum Video ConversionReplies: 2Last Post: 25th Nov 2011, 17:34 -
Something wrong with DivxToDVD download here?
By gastrof in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2011, 11:46 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 19:27 -
VirtualDub Output Too Large
By solarblast in forum EditingReplies: 2Last Post: 26th Dec 2007, 21:30 -
divxtodvd problem
By BPH2002 in forum Newbie / General discussionsReplies: 31Last Post: 27th Jun 2007, 09:17
