I Installed the Svcd 2 Dvd 2.0 Latest Version and I cannot see the settings tab on the Left hand side . I can olny see movies and Menu. I see the Gear icon at the top that allows me to see some options, but I cannot see all the options like full and wide screen option anyone no what could cause this?I tryed this on 2 differant pcs uninstalled this and re-download and re-registered serveral times.
Results 1 to 11 of 11
That is correct. Some options have been removed and added throughout the various builds.
I can see it when I fresh install then it disapeers after 1 conversion,and the full and widescreen box works well for me, problem is then if i use this version to convert to watch on my 43" tv the picture is small off centered and not right how can I get a build that has this 100%.and that option tab?
I have a older Version from my buddy his has this option I need a Xml reg file it wont let me manual reg, my reg email is uwantmore@comcast.net thanks for your help. -
that option tab is now gone. The options/settings are now available from the toolbar.
I see them but theres no full or widescreen option so on a larger tv the box stays small and to the left anything I can do?
Well that option was only ever for half-D1 AVI conversions.... i.e encodings wherer the bitrate was less than 3000kbs. To achive the same "setting" add the following string in your registry:
HKEY_CURRENT_USER\Software\Badger I.T.\SVCD2DVD 2.0\Settings\Process\AVI2HALFD1
with a value of "WS"SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Yes but that option only comes into effect when you have AVI assets of a total duration which would mean that the encoded bitrate is less than 3000kbs i.e over 2 hours+ of avi material.
ok well that does me no good then ,why is it that when I convert any mpegs to dvd and I play it on a smaller tv its ok if I put it on my larger tv theres problems with the picture being to the lower left and widescreen. I can change the tv to 4x3 /16x9 /all the differant settings and I get the same problem.
I have the older version and I did a movie at my buddys with that 1 works fine on my tv but I can't reg the older version because I think he downloaded with his username.I hit cancel and enter my info but it doesn't register just closes that window.I guess I bought something that don't work.And I know what ever options we had set on his works like a champ and alot of them options are not in my version so i'm screwed . -
Well as i said - that reg setting is the only difference.
I will refund your registration.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
thanks alot for the refund,this program would be great if it worked like the version my buddy has, and I was able to watch dvds made on all tv sets large small,but olny being ever to watch dvds I made with svcd2dvd 2.0 on a 20" tv is crazy when I have a 42" flat screen.If there was a setting in svcd2dvd to use full or wide screen with mpg conversion ,or maybe a check box for 4x3 or 16x9, I tell all my buddys to buy this to convert there 2 -3 cd disk to 1 dvd-r .it is a great dream that this svcd2dvd will once again work like my buddies.and one would be ever to choose the options needed to watch on all tv's
Black Magic Intensity Pro: Issue with xbox 360 settings
By dreamboss in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2012, 20:50 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
Capture settings or other issue? (Interlaced video, and a few questions...)
By DonnieC in forum Capturing and VCRReplies: 5Last Post: 30th Sep 2008, 13:03 -
Issue with 'Preview' and settings
By flaffer in forum ffmpegX general discussionReplies: 0Last Post: 4th Jun 2007, 15:36
