My problem is How can I convert my.avi file to DVD (playable in dvd players with menus and stuff)... I have programs like TMPGEnc Plus and DVDLab Pro... When I converted my .avi file TMPEnc it turned into an M2V file.... Is this corrrect ??? What should I really do.... help...
Search the how-to section (links on the left side of this page), and look for guides for the tools you have. Guarantee they'll tell you what you want to know.
occasionally larger than 255 characters -
If in doubt, Google it.
Hi Tensai,
Welcome to the forums.
The format you need for DVDs is called MPEG2. An M2V file is the video only part of the MPEG2 format. The audio can be in a number of formats. Look under the "What Is... DVD" link at the top left of the page for details.
You can either have the audio seperately (so you'll have 2 files - one video.m2v and one audio.wav/mp2/ac3, or the audio joined with the video footage.mpg. It is possible to just have video.mpg (i.e. no audio).
Where you have seperate files and ending in M2V or WAV/MP2/AC3, these are called "elementary streams". Where you have either the audio only, video only or both in the same file but all ending in MPG - these are called "system streams".
What next? Well, once you've got your audio and video file(s), they need to be authored - this is when you create menus (if you want them), chapters, subtitles etc. and then output them all bundled up into the VOBs - the same as those you see on commercial DVDs. You also get IFO files (InFOrmation about the DVD) and BUP files (BackUPs of the IFOs).
All these files are put into a VIDEO_TS folder, with an empty AUDIO_TS folder (this is for audio DVDs). The two folders are then burnt to disc for you to enjoy.
I hope that sheds some light on the black art...
If you need more, there is a wealth of information in the guides and articles and the question you have has probably already been asked, so be sure to search the forums. If you get stuck, post in the forums.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Here's a guide on how to author with dvdlabpro.
https://www.videohelp.com/guides.php?link=602 -
Hello... OK I've finished everything and works fine in my PC... Got another problem... The video I have has already a subtitle in it... I already burned it to DVD.... If I play it in the PC I could read the subtitle but if I watch it in the TV the subtitles cannot be read.... Could I fix this ???
Originally Posted by Tensai
Your footage can be fixed, but you'd need to resize it down a little, add black borders and then re-encode to MPEG2.
Search the forums (I'd start with a search on "overscan"), this process has been described numerous times.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 12:30 -
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
converting broken avi file to dvd
By dvdnewbie64 in forum Video ConversionReplies: 1Last Post: 14th Dec 2008, 19:05 -
Converting avi file
By frednufc in forum AudioReplies: 1Last Post: 28th Nov 2008, 17:20 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
