Hey there, this is my first time posting here and I really needed help trying to solve a problem I'm having with my DVD player. Okay, I know for a fact that there were two versions of the Toshiba SD-3960 DVD player, one which could not be hacked, the other that could. Fine, however, there is mention that you can change it from NTSC to PAL, yet, at the same time, from what I hear in other forums, that you cannot? Which is it? I'm asking this because I wan't to purchase two R2 DVDs, one NTSC and the other PAL, however, I cannot tell the difference between the two of them. I really would like help, since this is something that is killing me and bothering me as well.
BTW, what is the difference between this player and the old one and do you know if there is any way to clean the DVD inside using some sort of disc? Off topic, I know, but I didn't know where else to put this.
Maybe I should have worded it differently. Yeah, to make it simple, I know that there are two verisions of this Toshiba player, one that you can hack, the other you cannot. I just want to if it's able to change from NTSC to PAL, but there's option called ''Auto'' but do know what is it.
Toshiba SD-4700N DVD Player
By pat8671 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 19:06 -
Toshiba SD-K770 DVD player
By diet_mountain_dew in forum Video ConversionReplies: 1Last Post: 8th Dec 2009, 14:14 -
Original part# remote control f/ toshiba Sd -3960
By thebirdf in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2008, 16:17 -
Firmware for Toshiba HD DVD player
By tmelo38 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 1st Nov 2007, 20:02 -
Phillips 3960
By warr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Nov 2007, 10:35
