I'm looking for a VCD Template for TMpgenc to fit AVI/Video to One 700MB CD in VCD/Mpg1 Format.
I had seen some here before but cant seem to find them.
I don't know of any templates specifically for this purpose, as all you need to do is put in the correct bitrate and pretty much any video (within reason) will fit one CD, which gives any template you want to use the ability to do this. If you are altering the bitrate from VCD spec then you should choose MPEG-1 Video CD (non-standard) as the system stream type.
There's a couple of guides here that show you how to make your own template to do this:
http://members.dodo.net.au/~jimmalenko/TMPGEnc1CD.htm
https://www.videohelp.com/guides.php?guideid=85#85
... or maybe you were after the KVCD templates:
http://www.kvcd.net/dvd-models.htmlIf in doubt, Google it. -
Thank Jim, You are right in everything you said.
BUT.I had seen Some different Template's to do this, It's for My brother, I did end up just making one for him in the end. I just really wanted to find the one I had seen on the site before,But this was about 2 years ago.
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 16:04 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 10:52 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 08:09 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 18:54
