I have just converted a video from AVI to DVD using cucusoft, and im trying to burn it using Nero6 but it says if its over 2 gb's i need to burn it using the UDF option, but if i burn it using the UDF option, it doesn't work on my DVD player, so i was just wondering if theres any way to adjust nero so it works, or any other good DVD burning programs
cucusoft created one big VOB file ???
If it is truly converting (and presumably authoring) to DVD then it should split the VOB(s) into 1GB chunks.
Irregardless, this guide may be of assistance:
https://www.videohelp.com/guides.php?guideid=723#723If in doubt, Google it. -
please try post in correct forum. avi to dvd is not dvd to svcd,avi. moving you.
Converting and Burning DVDs
By OtosReborn in forum Portable VideoReplies: 13Last Post: 6th Apr 2010, 20:59 -
Problem with Burning DVDs
By The Monkees in forum MacReplies: 2Last Post: 25th Oct 2009, 01:00 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 12:53 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 18:08 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 20:37
