Hi
If Max Bitrate for DVD video is 9800kbps, then how much Max bitrate the PCM audio uses?
What tools can tell me the bitrate of PCM files?
PCM audio on a dvd is usually 1536kbit/s. It could be higher, http://www.mpeg.org/MPEG/DVD/Book_B/Audio.html
The total dvd bitrate cannot be higher than 10080 kbps.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 12:29 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
PCM WAV file bitrate too high?
By djdust in forum AudioReplies: 1Last Post: 19th Feb 2008, 16:05
